Go Back   SmokStak > SmokStak® Antique Engine Community > Hot Air Engines
Hot Air Engines Stirling engines, Rider-Ericsson and others.
Hot Air Engines
More help for #5 Robinson
this thread has 2 replies and has been viewed 2905 times
Old 03-16-2010, 10:02:29 AM
robinson456 robinson456 is offline
Wink More help for #5 Robinson
Does anyone have a good idea what the clearance should be between cylinder and piston? Having the engine resleeved.
Old 03-16-2010, 09:41:10 PM
Orrin Orrin is offline
Default Re: More help for #5 Robinson
When I build my model Stirlings with piston diameters on the order of 2-inches I make the clearance as small as I can, less than a thousandth of an inch. If the piston will not pass through the upright cylinder under its own weight, the clearance is too tight. When it just barely makes it all the way, it is just right.
Orrin
Old 03-18-2010, 02:42:24 PM
Dave Allen Dave Allen is offline
Hi robinson 456
Here are the original drawings for the No5,it just gives the piston and cylinder measurments as 7.5".I would guess a clearance of 1or2 thou would due,if this proves to tight you always have the option of honning the cylinder out a bit more.Sorry that the drawings were not of any help.
Regards Dave
Name:	robinson No5 001.jpg
ID:	75657   Click image for larger version
Name:	robinson No5 002.jpg
ID:	75658   Click image for larger version
Name:	robinson No5 003.jpg
ID:	75659   Click image for larger version
Name:	robinson No5 004.jpg
Robinson Steam engines Corey Robinson Steam Stationary Engines, Traction Engines 22 07-03-2012 08:28:25 AM
Help for #5 Robinson robinson456 Hot Air Engines 4 02-06-2010 11:23:32 AM
Swayne, Robinson & Co. Corliss Engine David Steam Stationary Engines, Traction Engines 1 01-26-2009 11:13:56 PM
Robinson Hay Press Anonymous Farm Antiques and Collectibles 8 07-13-2008 10:03:55 PM
Robinson Hay Press Craig Antique Engine Archives 0 02-16-2002 01:46:32 AM
