Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Military MEP and Aircraft Gen-Sets
US Army Ordnance Battery Charger (12V Generator)
this thread has 18 replies and has been viewed 8894 times
Old 01-28-2011, 01:39:51 AM
Default US Army Ordnance Battery Charger (12V Generator)
Found this little beauty at the scrap yard today (its amazing what people sell for scrap). Tag reads US Army Ordnance, Battery charger, portable gasoline engine driven, 12 volts 133 amps 2000 watts, continuos duty 2350 rpm,, operating weight 240 lbs, manfactred by Pioneer Gen-E-motor corp, Chicago Illinois, model BG20L, serial# 2458, date 6-30-51, looks like theres a little more, but I need glasses to read print that small.
Engine is Briggs & Stratton, engine model 23FBP, type 203567, serial#145416
The electrical panel has plugs labeled 6V & 12V, under cover is an amperage meter and a knob to decrease/increase amperage.
What would this have been used for? Charging batterys for tanks, radios, turret guns, radar sites, missles
Old 01-28-2011, 02:17:38 AM
John Newman, Jr.'s Avatar
Default Re: US Army Ordnance Battery Charger (12V Generator)
I think your engine is from Sept, '52. Got this from the ASECC data pages, but they don't mention a 23F, so I went back to the original 23 and came up with this date.
Is that a fuel pump on the back side of the engine?
Great find!
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 01-28-2011, 02:38:50 AM
Exclamation Re: US Army Ordnance Battery Charger (12V Generator)
Neat outfit! I like the Nelson muffler! With that muffler, you probably will hear more mechanical noise from the engine than exhaust noise from the muffler!
Old 01-28-2011, 09:59:20 AM
K D Redd K D Redd is offline
I have the parts book for the 23FBP. The "F" means Flange Mount, The "B" means Ball type main bearing. There may be only one between the engine and the generator or it may have ball bearing for both main bearings. The "P" means Fuel Pump.
Check www.then-now.com or call 781-335-1579. This company build fuel pump kits with modern material that can handle what we have that is called gasoline today. If you have running problem with the engine as you throttle it up, you will think you have a carb problem. It is NOT a carb. problem! It IS a problem with a bad magneto coil. Coil, P/N 290880 is NO Longer Available from Briggs. I have designed a coil conversion for this engine. The info was published in the Nov. 2005 issue of Gas Engine Magazine. I found out recently that the article is posted on GEM's website. Search the articles title " Cheap Fix ". You CAN NOT eliminate the engine points with one of the universal electronic ignition kit for small engine BECAUSE this engine has a ignition advance mechanism on the camshaft. If you try, when you go to start the engine, it WILL jerk the rope from your hand as it will fire early. I also found out recently that all Briggs engine before the Five and Six digit model number use a plug gap of .025 inch. NOT .030. This engine is .025 inch. Point gap is .020 inch. I collect these engine. I have a full set of the Numerical series that run. I do not have any generator but I have two that are Protable Fire service water pumps.
I forgot to mention I like the MILITARY GAL telling the men to keep the engine cool. The military used the same caricature on the care manual for the M-16's when they had the jamming problem on the weapon during it's first used in Southeast Asia.
Kent
The Following 2 Users Say Thank You to K D Redd For This Post:
Old 01-29-2011, 12:39:35 AM
Thanks Redd, great info to know. Not sure when I'll get around to fixing this one, there are already 2 engines I'm working on, and I have my big surfacing machine torn apart at the moment, so I'm full up on projects. This engine turns over very smoothly, theres just no compression, but I'd bet its just junk in the valves.
So no guesses on where this genny was used? I've seen lots of military generators, this is the first I've seen with an U.S. Army Ordnance tag, any suggestions on how to find its military application?
K
Old 01-29-2011, 01:26:03 PM
Exhaust valve is likely stuck.
Kent
Old 01-29-2011, 03:37:59 PM
ichudov's Avatar
ichudov ichudov is offline
The girl looks very cute. Awesome find!
I hate you!
The Following User Says Thank You to ichudov For This Post:
Old 01-29-2011, 04:41:45 PM
wassbiplane wassbiplane is offline
Back in the 60's the M-75 armored personnel carriers had lotsa radios--big ole radios-with filaments in the tubes---drew lotsa watts--when you parked that thing, 1st order was to hookup the battery charger to keep from runnin the batteries down---that big old 6 cyl opposed air cooled Continental made too much noise & used too much fuel to keep runnin.
Jerry
The Following User Says Thank You to wassbiplane For This Post:
Old 02-01-2011, 08:00:25 PM
oldphartsusedparts oldphartsusedparts is offline
nice find. mine was going for scrap too,before i rescued it.had a stuck valve also.all the info about mine along with pics on are on another thread here.take a look. ken in vernon b.c. canada
Old 02-01-2011, 11:42:47 PM
Hi Ken, got a link to that thread?????? Thanks, Kristin
Old 02-03-2011, 10:57:50 PM
Joseph Joseph is offline
I have two of these one just like yours and one with a 2 cyl onan engine also have the funny looking cable to connect the charger to the batterys. On my unit the control knob next to the amp meter adjust the voltage. I hook it to a dead optima battery a turned the knob all the way up the voltage increased to 16 volts. I had to rebuild the engine on the onan powered one which was fun since no parts can be found. I had to make my own crank shaft bearings by turning them on a lathe out of a 5 inch dia. chunk of babbitt. My Briggs powered unit needs to be rebuilt also as it is stuck from setting out in the weather.
Old 11-21-2012, 10:43:17 PM
Cinnamon Cinnamon is offline
hi Joseph,
I/we have one of these same Battery Chargers (with a B&S engine) sitting in our garage (except it doesn't have the "Keep this Engine Cool" gal on it! It hasn't moved for some years and I have no idea if it works or not - belonged to my partner's dad. I need to free up some space - don't suppose you can suggest a way to find a good home for it and any idea how much I should ask? We are in Louisville, KY. thanks
Old 11-24-2012, 11:48:07 PM
Cinnamon I have no idea what a fair price would be as far as finding it a good home I would try the classifieds on this site.
Old 11-25-2012, 12:13:04 AM
PM me. I will be in Louisville this Friday.
Old 11-25-2012, 09:45:34 AM
I have one of these same chargers but it needs to go to free up garage space. Can anyone suggest a value or a good way to sell?
Old 11-25-2012, 12:10:54 PM
Elden DuRand's Avatar
Good find, Girl!!
How come I never find anything like that on my excursions??
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 07-01-2013, 07:08:54 PM
bicycle4u bicycle4u is offline
Ref parts list for this 23FBP generator that K D included in his discussions herein... does anyone have a copy of the parts list that I can download? I just purchased the same 12V generator for $27 at a nearby auction in Omaha... didn't realize it was a 12 V until after I raised my paddle (after I had the chance to look it over)... engine runs well, as it was maintained by the Corps of Engineers.. but what am I going to do with a 240 lb 12 V generator... convert it over to a 15 kw or so ac alternator possibly?... anyone have any ideas? My first post!
Old 07-01-2013, 07:28:19 PM
Power Power is offline
Nice, Dalmation - fix 'er up, put wheels on cart, and when your fork lift or crane battery goes dead, you can quickly charge it wherever it is - no need to drag back to electricity.
Old 07-02-2013, 02:11:14 AM
I still have it, and its still on the "to do" list, maybe this fall when I'm on vacation. I was thinking it would be a great battery charger for my off-grid cabin, another project on the to-do list
Tiny Tim Generator/Battery Charger John Schwiebert Generators & Electric Motors General Discussion 23 05-18-2017 01:21:13 PM
Battery Charger Jerry B Computer, Camera and ISP Problems 5 08-09-2010 07:27:23 AM
Onan battery charger Joseph Onan Generators 2 10-28-2009 03:13:24 PM
48v battery charger. envelopes2007 Onan Generators 3 01-06-2008 01:33:17 PM
1920's Battery Charger ? Dean Suhr Generators & Electric Motors General Discussion 2 01-27-2004 02:42:36 PM
