Penberthy Oiler Issue
this thread has 15 replies and has been viewed 2190 times
Old 02-20-2011, 03:35:21 PM
billludwig billludwig is offline
Default Penberthy Oiler Issue
I just picked up a 1 1/2 hp Stover hit & miss, and it runs great, but I'm having trouble with the Penberthy oiler. The oiler drips just fine, until I start the engine. With the engine running, the oil stops dripping. As soon as I shut the engine down, the oiler starts dripping again.
Do I have some kind of blow-by issue??
Thanks,
- Bill
see attached pics showing the oiler I have.
Name:	2011-02-20 10-00-24 - DSC_0414.JPG
ID:	100905   Click image for larger version
Name:	2011-02-20 10-01-17 - DSC_0417.JPG
Old 02-20-2011, 03:53:08 PM
loggerhogger loggerhogger is offline
Default Re: Penberthy oiler issue
cylinder oilers have a check ball in the base that keeps the cylinder pressure from blowing the oil back up into the oiler. If yours doesn't have one, then that is more than likely your problem.
The Following User Says Thank You to loggerhogger For This Post:
Old 02-20-2011, 04:02:35 PM
Strange, I've had the oiler apart and can't see where a check ball would even fit...make sense what you're suggesting though. Thanks.
---------- Post added at 01:02 PM ---------- Previous post was at 12:59 PM ----------
Oooops! I just found the ball check -- at the base of the sight glass. Seems to be nice and free. Any other suggestions?
Old 02-20-2011, 04:10:29 PM
make sure that it is free of any junk that might prevent it from seating. You might even try opening the needle valve a little more when the engine is running, and see if that makes a difference.
Old 02-20-2011, 07:11:36 PM
It is completely free from junk, but I just noticed that, the ball is resting on a cross-pin, keeping it off-center (see pic below - it is taken straight down the lube tube), which is allowing blow-by. Is that pin normal, or is there supposed to be a real seat of some kind at the bottom of the ball?
Name:	2011-02-20 16-12-15 - DSC_0463.JPG
Old 02-20-2011, 07:33:09 PM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
I believe it should seat when the compression blows it up against the top.They don't seat in the bottom or the oil can't get past.I take the ball out, and drill 3/16 in the coupling on the down pipe under the oiler..Works fine for me.
The Following User Says Thank You to Dick Graybill For This Post:
Old 02-20-2011, 07:41:08 PM
Yes, Dick, it seats when compression blows the ball up. However, the ball is not getting blown up. I can barely feel any pressure blowing up the tube when the engine is runnig. Plus, the ball is maybe 1/8" below the upper seat, and I don't think the ball can get blow up that far with such a small amount of pressure. Also, I can see the oil reservoir bubbling as I would expect with the ball not seating.
Old 02-20-2011, 09:09:33 PM
Roger Kirschenman Roger Kirschenman is offline
Default Re: Penberthy Oiler Issue
looks like a home made cylinder oiler. Ball is to far from set & looks like steal witch would make it to heavy, a little copper ball is best for that application, it all so needs a vent tub.
The Following User Says Thank You to Roger Kirschenman For This Post:
Old 02-20-2011, 09:23:33 PM
You're right about it being a heavy steel ball, Roger. I'll try to find a smaller copper ball, although I have no idea where to look...
Also, can you tell me more about the vent tube?
Thanks,
Bill
Old 02-20-2011, 10:55:15 PM
GregKinder GregKinder is offline
I have several engines with machine oilers on them (no check ball) I do just what Dick said but with the hole drilled on a slight angle upward it helps to keep the oil from dripping out of the coupler into the hopper.
The Following User Says Thank You to GregKinder For This Post:
Old 02-20-2011, 11:45:30 PM
I'm not understanding exactly what you and Dick are suggesting regarding the 3/16" hole drilled in the coupler. Where in the coupler is the hole drilled, and what does it do?
Thanks!
Old 02-21-2011, 12:18:29 AM
My oiler pipe needs a pipe coupler threaded on it for the oiler to screw into.I drill a hole through the side of the coupler.What it does is let the back pressure or blowby escape instead of blowing up through the oiler.All my engines are set up like this without any problems.
Old 02-21-2011, 12:28:03 AM
I understand now, Dick. Thanks to all of you for the help with this. I'll give it a try!
Bill
Old 02-21-2011, 11:59:52 AM
I drilled the "vent" hole, and it worked GREAT! The final question is...what is the recommended drip rate for the oil?
Old 02-21-2011, 12:18:48 PM
Glad it worked. I set to 3 or 4 drops of # 30 non detergent per min.
Old 02-21-2011, 12:48:46 PM
Thanks, Dick!
- Bill
Penberthy isn't the same Penberthy David Steam Stationary Engines, Traction Engines 74 12-02-2013 07:43:21 PM
Big Penberthy Mark L. Jordan Steam Stationary Engines, Traction Engines 13 09-20-2010 11:43:13 AM
6hp Witte oiler issue Chris Steffen Hit & Miss Gas Engine Discussion 4 05-28-2010 12:48:04 PM
Penberthy A 22 Injector Jeff Smith Steam Stationary Engines, Traction Engines 3 12-11-2008 07:02:52 PM
Penberthy Injector oiler M.Smith Antique Engine Archives 3 09-22-2003 08:43:52 PM
