Early Style Two-Cylinder Kinnard Haines Tractors
this thread has 79 replies and has been viewed 26326 times
Old 12-14-2014, 12:28:01 AM
Benjamin Roth's Avatar
Benjamin Roth Benjamin Roth is offline
Default Re: Early style two-cylinder Kinnard Haines Tractors
Here is another view of the place. The building in the center is the Blacksmith shop built in 1924. It had a 5 hp. Faultless powering a line shaft with an air compressor, pedestal grinder, post drill, 25 lb. trip hammer, and a lathe. The other red building to the right and in the distance was the elevator built in 1926. It had a 6 hp. Field engine in the basement later replaced with a 6 hp. M International and eventually an electric motor. You can see how the iron is all spread out. Lots of time was spent sweeping with a metal detector and prying things out of the ground.
The brochure picture of the tractor has a muffler below the left cylinder. I'm not sure if this is correct for the tractor but it was in the pile. If it's for something else does anyone recognize it?
I had posted this in the other thread with the single cylinder tractor. I think it's a neat signature piece for the tractor. The bolt in the clevis was loose and would still turn out by hand!
The drawbar guide. It's interesting to see the blacksmith work on these parts.
Some front axle parts. The K 68 number is the same on the 40-70 Flour City tractors. Looking at the original tractor picture Jeff Wahl posted Here it appears the front axle casting is the same as the later tractors like the 40-70.
ID:	213380   Click image for larger version
ID:	213381   Click image for larger version
ID:	213382   Click image for larger version
Old 12-19-2014, 01:24:22 PM
acat65 acat65 is offline
at least I don't think Ben will be setting at the local bar all day Gene
The Following User Says Thank You to acat65 For This Post:
  #63
Old 12-20-2014, 11:35:02 PM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
Here is another photo of a two cylinder Flour City tractor:
-Jeff
wahlengines.com
Old 12-29-2014, 01:59:43 PM
Jeff Wahl's Avatar
Scanned this in the other day:
-Jeff
wahlengines.com
Old 01-03-2015, 05:07:01 PM
Retrofit88's Avatar
Retrofit88 Retrofit88 is offline
Happy New Year All.
Benjamin,
Please let us know what parts you have for the Little Bull. Thank you for posting all the pictures.
The Following User Says Thank You to Retrofit88 For This Post:
  #66
Old 01-05-2015, 07:42:42 PM
OTTO-Sawyer's Avatar
Photo Re: Early style two-cylinder Kinnard Haines Tractors
Somehow I missed this thread before, but figured I'd repost a picture I posted in another Kinnard Haines thread now that I saw the catalog shot Tom posted in Post #11.
I have the Original picture from the Reed Brothers unit in front of the barn and a couple other shots of it.
Figured they may as well be shown together.
ID:	215152   Click image for larger version
Name:	Reed Brothers threshing rig & Shredding North of Afolke Illinois.jpg
The Following 11 Users Say Thank You to OTTO-Sawyer For This Post:
  #67
Old 01-05-2015, 08:16:43 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
That thresher has an interesting stacker!
The Following User Says Thank You to Tim Colwell For This Post:
  #68
Old 01-07-2015, 01:00:14 AM
Nikki, all the Bull parts I had went to another collector. There were only two or so parts so there wasn't much at all. All the parts I had for other tractors are also gone now to help pay for the Flour City project.
Otto, that is interesting to see an original picture to compare to the catalog. I had done some scaling from the two cylinder drawing in the catalog but it seemed like the proportions weren't matching what I already knew. I thought the catalog was more artistic than it was photograph.
Here is a picture of some fresh castings for the tractor!
Old 01-23-2015, 07:41:14 PM
As per the 'testimonial' they sent in with their picture the thresher is an Advance 32x52 with self feeder and attached stacker.
They also mention the shredder in the other picture as being a 12 roll Advance Husker Shredder.
I believe they were already using BOTH of the Advance units with their previous power source which was a large portable engine.
  #70
Old 12-18-2015, 11:59:33 PM
Ben,
Did you ever find or make any new parts?
Tim Colwell
JD & IHC corn sheller and engine collector.
Old 12-23-2015, 11:53:38 PM
Tim,
No, did not find any new parts or even leads. I haven't made any new parts yet either, too busy with other projects. I am slowly working on modeling the entire tractor with CAD and have about 40% finished. The frame itself has been taking a lot of time because of all the unknowns.
I attached two pictures showing the collection of parts as they are now. There are a few 20-35 FC parts and possibly a few things that are something else entirely. It may not look like much but I am excited to get started on this project.
ID:	242101   Click image for larger version
Old 09-05-2017, 11:12:24 AM
Ben,
I thought you were behind this but forgot to ask when I met you. Any new castings or progress?
Tim Colwell
Old 09-12-2017, 12:05:49 AM
Hi Tim,
It was nice meeting you at Rollag. There have been a few more castings poured. More is in the works but will take awhile yet. The goal for now is to start assembly next fall.
The Following 4 Users Say Thank You to Benjamin Roth For This Post:
  #74
Old 09-12-2017, 07:14:55 AM
Don Selmer Don Selmer is offline
Ben, I sent you a PM
Old 09-23-2018, 10:38:15 PM
Any more castings poured, or started putting parts together yet?
Mike
Old 09-25-2018, 10:22:49 PM
Nothing new yet. Some castings are still in the works. I have been studying other Flour City engines and tractors and taking notes. Haven't learned anything big or found any new parts.
Here is a somewhat recent solid model. Most of the major parts are figured out. The details though...
Old 09-27-2018, 10:19:34 PM
Smile Re: Early style two-cylinder Kinnard Haines Tractors
Man that model looks nice! I bet you've got QUITE a few hours into that. I spent ten years as a full time CAD draftsman, but never did get much into 3D stuff, other than a few little parts here and there. I remember spending one whole day laying out JUST one part in 3D, to make sure I got the three angles correct that had to tie in together on that piece. Never did get into solid modeling, but I wish I had. I started out drafting with CAD back in 1995, and it's amazing to me the leaps and bounds technology has grown since then.
Keep up the amazing work, I know someday you'll have a finished machine that we will all look at and drool over, just like Kory Anderson has done with his 150 Case.
Mike
The Following 2 Users Say Thank You to Mike McKnight For This Post:
  #78
Old 09-27-2018, 11:01:55 PM
Talking Re: Early style two-cylinder Kinnard Haines Tractors
I agree Mike.
When Benjamin puts his mind to something...….it happens.
It might TAKE a while but...…..
  #79
Old 11-11-2018, 11:10:45 PM
Default Re: Early Style Two-Cylinder Kinnard Haines Tractors
I was happily informed of a new part this week! Turns out the 30-50 used the same steering worm wheel (and worm too I would imagine) as this tractor.
Thanks Mike! I really admire the guys that did use and the ones that still do use 2d CAD. I have used it and much prefer the 3d stuff!
Craig, yeah, you got me there. Good things are worth the wait!
The Following 8 Users Say Thank You to Benjamin Roth For This Post:
  #80
Old 04-28-2019, 12:22:29 AM
And here they are. I am glad that Kinnard and Haines used some of their early work in later tractors!
Early Style Governor 6 Hp. IHC LeRoy IHC Hit & Miss Gas Engine Discussion 0 10-18-2017 10:51:06 AM
Kinnard-Haines Flour City David Parfitt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 205 09-20-2017 09:01:16 AM
Detroit 3 Hp early style rjdadio Antique Engine Photos 1 06-29-2017 09:57:16 PM
Kinnard Haines - Flour City Tractor Chris J Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 11-23-2010 10:48:11 PM
Kinnard - Haines Co. Engines Denis Rouleau Hit & Miss Gas Engine Discussion 4 09-26-2009 06:08:39 AM
