Sleeper trailer-9
this thread has 2 replies and has been viewed 2921 times
Old 07-12-2011, 06:41:53 PM
JDcrawler JDcrawler is offline
Default Sleeper trailer-9
With the interior paneling all in, it's time to start on the cabinets.
This is the support framing for the counter top and the icebox.
Test fitting the icebox.
This is the the icebox that was in the camper and it came with a layer of Styrofoam molded right around it.
The frame for the icebox is finished off on the side with a section of paneling.
I mounted a 12 volt light on the side also.
I then added more more Styrofoam to the inside of the icebox frame.
It has a 1 inch thick layer of foam on the top, sides and bottom and 3 inches added to the back.
The Following User Says Thank You to JDcrawler For This Post:
Old 07-12-2011, 06:43:54 PM
Default Re: Sleeper trailer-9
The icebox door is taken apart and the old piece of paneling was removed.
I put in a new piece of paneling and re-assembled the door.
The old counter top in the camper already had a section of the counter the was hinged so it could be lifted up.
There was room for a small Colman cook stove under this part of the counter top.
I trimmed the counter top down so it fit next to the icebox frame.
Here's how it looks with the hinged part of the counter top in place.
Old 07-12-2011, 06:45:56 PM
I cut a square section out of the table top that was in the camper.
This piece is fastened to the underside of the counter top.
The table top had an aluminum trim strip around edge so I used a section of that to trim the front edge here.
The piece from the table top will have the sink mounted in it.
This way we can have a nice counter area to work on and then we can lift it up to use the sink.
Ray
The Following 3 Users Say Thank You to JDcrawler For This Post:
Sleeper trailer-8 JDcrawler Trucks, Trailers and Hauling for Shows 8 07-07-2011 02:01:13 PM
Sleeper trailer-7 JDcrawler Trucks, Trailers and Hauling for Shows 8 07-04-2011 10:11:28 PM
Sleeper trailer-6 JDcrawler Trucks, Trailers and Hauling for Shows 6 06-30-2011 09:22:51 PM
Sleeper trailer-5 JDcrawler Trucks, Trailers and Hauling for Shows 3 06-15-2011 06:38:36 PM
Sleeper trailer-3 JDcrawler Trucks, Trailers and Hauling for Shows 2 06-09-2011 01:14:09 PM
