Paint Shop
Do we need Primer on Bare Cast Iron?
this thread has 21 replies and has been viewed 7990 times
Old 07-04-2019, 01:46:33 PM
Mark20h Mark20h is offline
Default Re: Do we need Primer on Bare Cast Iron?
I have ben debating weather to use urethane or epoxy primer on a hit and miss engine. The urethane is a high build and both have to be sanded before painting. How do you sand all the areas on a engine. or is there a different type of primer that doesn't require sanding?
Old 07-05-2019, 08:05:27 AM
cobbadog cobbadog is offline
G'Day Mark,
Read post #6 in this thread and this may help you decide. Also keep reading the following replies as you will discover when it comes to painting you will get out what you put in. Little effort can equal a poor result. Select a paint product range where you can buy a primer and top coat of the same brand as these are designed to work together. Your cast iron usually has a rough surface so it is impossible to rub it back properly after a high fill primer has been applied but you should at least try. I sprayed an etch primer directly onto the cast iron and alloy parts and then top coat directly onto that but with the tinware I have applied a primer filler and will have to wet rub them back for a best result.
Malleable Iron or Cast Iron wagonbuilder joe Horse Drawn Equipment 10 01-16-2018 12:07:57 AM
Broken Sub Base: Mold, Cast, Cast Iron Weld DaveTexas Hit & Miss Gas Engine Discussion 24 03-17-2011 12:00:46 AM
Stickney Cast Iron Seat Do You Need One Cast? Marshal Reysen Hit & Miss Gas Engine Discussion 5 04-08-2010 01:22:44 PM
Stickney Cast Iron Seat Cast? Craig A Hit & Miss Gas Engine Discussion 0 01-22-2010 09:01:44 PM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
