Installing brake box in 95 chevy silverado
this thread has 8 replies and has been viewed 8885 times
Old 07-07-2006, 02:27:25 PM
Forrest A's Avatar
Forrest A Forrest A is offline
Default Installing brake box in 95 chevy silverado
I am trying to install a trailer brake controller in a 95 chevy half ton and can't find a good spot to tap into the brake switch wire. Is there anyone here that has done this on this year and model? I have googled everthing I can think of on the subject, all I find is for 2000 models and on.
Thanks
Forrest
Old 07-07-2006, 02:29:27 PM
Jordan's Avatar
Jordan Jordan is offline
Default Re: Installing brake box in 95 chevy silverado
forrest are you talking about a device that controls electric trailer brakes??
Old 07-07-2006, 09:08:04 PM
Tom Marshall Jr.'s Avatar
Hi: The stop light switch is under the dash mounted on the brake pedal mount. Use a test light to find the hot wire and the work wire. tap into the work wire. ( it will be hot when you push on the pedal.) Tom
Old 07-07-2006, 11:39:12 PM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
Looking at a 1994 service manual it shows the stoplight switch wire is purple. look for the wire by removing the dash panel just below the steering column.
Old 07-08-2006, 01:09:13 AM
Phillip Hutchinson Phillip Hutchinson is offline
G'Day,
when i fit a brake unit thats to hard to get the stoplight switch wire i hook it up to the lume in the door pillars coz your already in there to run the brake to the rear of the vehicle in any case,some of the the modern cars you nearly have to destroy to get to the stoplight switch.
Regards Phillip
Old 07-09-2006, 10:23:40 PM
JLBroadhead's Avatar
JLBroadhead JLBroadhead is offline
I put an electronic brake controller in my 95 scottsdale and had to find the harness above the steering coloumn with several white wires in it then single out the switched wire worst part of the instalation.
Installing a fly wheel key Rag Hit & Miss Gas Engine Discussion 13 09-15-2009 11:09:22 PM
Installing staybolt steamer86 Steam Stationary Engines, Traction Engines 8 02-02-2008 12:25:23 PM
Attn: To ALL chevy guys, Chevy parts N.O.S. & Repro parts Sky Antique Autos and Trucks 4 08-31-2007 11:47:33 PM
Installing the Piston in an FM-Z 3HP Harry Hit & Miss Gas Engine Discussion 3 05-26-2007 11:15:49 PM
Installing handholes Rick Strobel Steam Stationary Engines, Traction Engines 24 12-07-2005 12:14:36 PM
