George Fifield Lathe
this thread has 12 replies and has been viewed 1943 times
Old 02-01-2017, 06:47:20 PM
Chester5731 Chester5731 is offline
Default George Fifield Lathe
I recently acquired a George Fifield metal lathe. I have the whole stack of gears. Can anyone help me find a chart or reference to what gear is used for what?
Old 02-01-2017, 10:03:24 PM
Default Re: George Fifield lathe
If you Google "change gear calculator" you can find a few programs that will help you out.
Old 02-02-2017, 01:49:32 PM
Thanks for the reply. I see I am going to have some reading to do when I get this thing going.
Old 02-02-2017, 08:02:57 PM
Any pics? Never heard of a George Fifield lathe.
Old 02-02-2017, 10:55:09 PM
I will have to get some this weekend then try and figure out how to post them.
Old 02-03-2017, 10:06:09 AM
Here is an ad from 1892.
Name:	G W Fifield.jpg
Old 02-03-2017, 10:45:59 AM
The chuck on mine looks a little different but it has that plate, the stack of gears and the steady rest.
Old 02-05-2017, 02:01:58 PM
Default Re: George Fifield Lathe
I hope the pictures come thru.
Old 02-05-2017, 02:03:59 PM
Try this one.
The Following User Says Thank You to Chester5731 For This Post:
Old 02-05-2017, 05:57:30 PM
I took the liberty to convert the lathe to a floor mount type.
Old 08-27-2017, 01:35:48 PM
rj1939 rj1939 is offline
Here is another George Fifield lathe, saved it from a very uncertain future, after a place closed down.
There is another trailer loaded with tooling that went with it, a good portion was a hodge podge of misc, not related the the lathe.
From what I have found, they didn't make any more lathes after @ 1894
Old 08-27-2017, 04:01:28 PM
That looks like a good sized lathe.
Old 08-29-2017, 08:53:55 PM
AngrySailor AngrySailor is online now
You could check the TPI on the threading lead screw then work out what ratio you need (or have gearing for) for various thread pitch/feed rates, 1:1 of course giving you whatever pitch the lead screw is. Don't forget that you do NOT count the IDLER gear in the ratio!
Sweet old lathes, I have one that looks very similar stashed away at my Fathers shop. It's only about 8-10" swing at most. Will have to check what make it is but I recall it had "1890 something" cast or stamped on it somewhere. Don't apply too much feed force through the rack or the cast rack will break, you can't run these hard like a modern machine and they don't like indexable carbide! Don't ask how I know
German George does it again! Richard Sturdy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 62 04-30-2014 01:11:26 PM
German George does it again! Richard Sturdy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 04-28-2014 11:14:28 AM
Lathe: Want information on your lathe? john11139 Machine Shop and Tool Talk 4 04-08-2013 06:39:52 PM
Thanks George! Richard Sturdy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 05-09-2010 01:37:30 AM
