Edison no 3 Spark Plugs
this thread has 3 replies and has been viewed 749 times
Old 04-22-2018, 08:33:42 PM
twistr71 twistr71 is offline
Default Edison no 3 Spark Plugs
Someone gave me about 20 of the plugs years ago
Anyone knows what they fit?
Seem kinda small for a car engine
Maybe for a model engine
Old 04-22-2018, 09:59:17 PM
Pat Barrett Pat Barrett is online now
Default Re: Edison no 3 spark plugs
If they are 10mm they are for early Chevy 6 cyl engines. (About 3/8" dia, at thread)
Old 04-22-2018, 10:21:50 PM
Ken Karrow Ken Karrow is offline
10mm Chef '41-'48, Some Tiny Tim type generators, somebody else chime in with more uses.
Old 04-25-2018, 07:23:03 PM
sparky49 sparky49 is offline
Default Re: Edison no 3 Spark Plugs
Also Packards and Buicks of the same era. Lots of these 10mm plugs out there for sale because they were easily fouled by the crude carbs of the day and most people had their heads drilled and re-taped for 14mm. Plug makers geared up to make those and then the market disappeared. Ironically, they are again making 10mm plugs for the computerized fuel injected modern engines.
Edison take-apart spark plug re-assembly batrider Magnetos, Ignition Coils and Spark Plugs 1 09-29-2016 08:23:17 AM
Edison spark plugs Ken Rose Magnetos, Ignition Coils and Spark Plugs 4 02-06-2015 08:52:09 PM
Edison spark coil? KeithW Magnetos, Ignition Coils and Spark Plugs 13 08-12-2011 08:59:22 AM
Unknown size spark plug (HC-42 Edison) Sky Magnetos, Ignition Coils and Spark Plugs 4 02-22-2010 12:12:28 AM
L 654 Spark Plugs CurTmu Kohler Generators 1 10-09-2009 12:16:30 PM
