1908 IHC Tom Thumb ignition?
this thread has 4 replies and has been viewed 2759 times
Old 08-10-2012, 08:43:30 PM
Johnny T Johnny T is offline
Default 1908 IHC Tom Thumb ignition?
Hello, I'm at work on my 1908 Tom Thumb engine and I have a question about the ignition timer for the buzz coil on my engine. I am enclosing a picture of what my engine has for the timer which is simply a piece of spring steel attached to the push rod which makes contact with a tab sticking out of the Cam gear, and then the ground is apparently attached to the little screw which I have a picture of as well.
The question I have is; is this the correct timer for my year of engine? I know that I've seen pics of later dated engines having a timing advance and that Don Oberholtzer sells these parts. So basically it comes down to, will my engine be functional, or do I need to purchase these parts? Thanks in advance, John
Old 08-10-2012, 08:49:53 PM
Default Re: 1908 IHC Tom Thumb ignition?
Here's the pic, got ahead of myself.
Name:	Tom Thumb timing tab.JPG
ID:	141959   Click image for larger version
Name:	Tom Thumb ground.jpg
Old 08-11-2012, 02:40:59 PM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
I have an early one with a wipe timer. PM or e-mail me your e-mail and I wiill get some pictures of mine.
Old 08-12-2012, 02:22:47 AM
AussieIron AussieIron is offline
Hi, This is timing off my little IHC. Is this the wipe timer you refer to? Often wondered if mine was original. No serial No on mine, but bronze con rod, detent arm, rocker and push rod so I think it's 1911/12? -Cheers,
Old 08-13-2012, 09:54:32 PM
Well It seems like every picture of a Tom Thumb's timer seems to be slightly different. I'm posting some pics here for Thomas Cwach, of his Tom Thumb's timer.
ID:	142319   Click image for larger version
ID:	142320   Click image for larger version
ID:	142321   Click image for larger version
The Following 3 Users Say Thank You to Johnny T For This Post:
1908 IHC Tom Thumb gas line MikeinIowa Hit & Miss Gas Engine Discussion 2 09-09-2015 07:34:54 AM
IHC Tom Thumb 1908 Restoration Johnny T Hit & Miss Gas Engine Discussion 3 01-27-2012 03:07:54 PM
1908 25 HP 1908 Fairbanks Morse - Where is it now? Larry Evans Hit & Miss Gas Engine Discussion 1 11-14-2011 08:46:22 AM
IHC Tom Thumb ignition help Alan R Hit & Miss Gas Engine Discussion 11 12-04-2009 01:11:45 PM
1908 IHC Auto Buggy Andrew Yeary Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 09-20-2009 10:15:21 PM
