'36 Ford ignition coil connections
this thread has 5 replies and has been viewed 1670 times
Old 11-15-2012, 11:08:27 AM
Default '36 Ford ignition coil connections
Hi all,
I had a call to test the ignition coil on a '36 Ford V-8. Before I go and make myself look like a bigger idiot than I actually am, what are the two primary connections? I've seen these coils but never tested one. Are the spring on the under side and the binding post on the top side the two I'm looking for? Is there anything special I need to know? I'm using an older Allen tester.
Thanks and have a great day!
Kirk
Old 11-15-2012, 11:26:40 AM
Keith Schumacher Keith Schumacher is offline
Default Re: '36 Ford ignition coil connections
The top terminal is hooked to the ignition with a resistor in the line. The bottom contacts the rotor in the distributer. I hope this helps. Keith
Old 11-15-2012, 12:09:25 PM
BHoward BHoward is offline
The spring and the terminal on top are the two primary connections . I think there,s another clip on the bottom for high voltage .Good luck ,Bill H.
Old 11-15-2012, 12:46:53 PM
Jerry Sweet Jerry Sweet is offline
The brush is the high tension,and rides on the collector ring of the distributor rotor.The system is pos. ground.Four volts +or- neg.connects to the top post.
Old 11-15-2012, 12:56:42 PM
OTTO-Sawyer's Avatar
I don't know if it will affect the readings or not, but don't forget that they were Postive Ground.
Negative to the top post, Positive to the spring on the bottom.(connects to points)
Spring loaded carbon rod is the high voltage connection to the rotor.
---------- Post added at 12:56 PM ---------- Previous post was at 12:54 PM ----------
Oooops....
Looks like Jerry already answered that while I was slowly typing and waiting for my post to upload.
Old 11-15-2012, 02:40:37 PM
Oooops....
Thanks for all of the replies! That's what I needed to know. The Allen tester has no particular polarity associated with it.
Kirk
Detroit Coil Company Ignition Coil jmacsuga Magnetos, Ignition Coils and Spark Plugs 8 12-10-2011 11:32:46 AM
Ford Straight 6 Ignition Timing? Radio Guy Onan Generators 11 04-11-2011 12:17:26 PM
Ford Ignition Coils Tom Wahl Antique Autos and Trucks 1 12-04-2010 11:45:57 AM
Buzz coil connections B. K. Lahey Magnetos, Ignition Coils and Spark Plugs 4 12-20-2008 11:47:11 PM
Interesting coil find: The Chief Super Ignition Coil packrat56 Hit & Miss Gas Engine Discussion 3 09-14-2007 09:16:19 AM
