16hp Briggs runs rich only on gasoline, not propane.
this thread has 3 replies and has been viewed 1719 times
Old 12-28-2012, 09:31:06 PM
rpmalerba rpmalerba is offline
Cool 16hp Briggs runs rich only on gasoline, not propane.
Hi, new memeber here. I have a 16 hp Briggs Vanguard Winco 9k Generator that ran just fine on propane. I bought a 1971 Onan 4k propane unit and will be selling the briggs/winco unit. I thought it would be good to have it run on gas also as a better selling point. So I took off the propane line and started it on gasoline. Problem is it runs rich with the air cleaner on. It runs 95% smooth with the lid off. Of Course the air cleaner is clean. I took the top of the carb off to look at the float, everything seems o.k? Can't understand why it runs smooth on propane but rich on gasoline. Any ideas? I set the plugs at 25 and 30 and had no change.
Thanks.
Old 12-29-2012, 04:15:23 PM
Default Re: 16hp Briggs runs rich only on gasoline, not propane.
I ordered an air filter on eBay. I have no past history of this unit and who knows whats on the air cleaner element? When the engine is at 3600 rpm and I try to remove the air cleaner and tin it actuall is a hard pull. I can feel the suction and that ain't right. I'm pretty sure that's my issue.
Thanks anyway and great talking to you.
Old 12-31-2012, 01:57:50 PM
Exclamation Re: 16hp Briggs runs rich only on gasoline, not propane.
You may find that the carb jets were drilled for propane, as well. If the carb is not set up as a duel fuel unti, it won't run properly on gas.
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 01-04-2013, 05:46:08 PM
I just got my new filter fron ebay with the foam outta filter. Fired the gen up and placed it on and there was no change in the rpm's. She ran great. So my old filter looked fine, light shined through the paper etc, but some how she was clogged.
Superior 25 hp Gasoline or Propane osage Oil Field Engines & Related Equipment 25 08-01-2015 08:42:15 AM
Economy 5hp Only Runs Rich? rogercsi Hit & Miss Gas Engine Discussion 12 10-21-2012 10:15:31 AM
Older kohler gen runs rich Chieffox Onan Generators 9 09-19-2012 08:57:25 PM
Propane to gasoline equivalents? Warren914 Kohler Generators 11 05-29-2011 03:17:10 PM
Volatility (gasoline vs. propane) flasks Hit & Miss Gas Engine Discussion 3 03-22-2008 09:37:47 PM
