E15 Ethanol
this thread has 66 replies and has been viewed 13667 times
Old 08-24-2013, 11:01:43 PM
OTTO-Sawyer's Avatar
Photo Re: E15 Ethanol
Decided to swing by there while it was fresh in my mind.
Hard to read as the stickers are faded out, but they do read 10% and 25%
And, Yes, They do also have the 'warning' stickers on the 25 & 85, even though there is No attendant on duty to ask for help, not that I ever wanted to anyway. As I've noted several times before, I have run all of them in my daily drivers and in my lawnmowers and everything else I have with engines. The motorcycles, (the short time I was riding) were the only thing I never got around to trying the E85 in, but I have run varying mixtures of it with the other blends in everything else. I also ran straight E85 in my 62 Chevy truck a couple times with no ill effects, and No noticeable loss of power.
If they don't want me to use it, they're going to have to make the nozzle too big to fit my filler neck..... otherwise it will continue to get used on occasion, sticker or no sticker.
Ya'll can just concider me to me a modern day 'shine runner', only it all goes in the tank instead of some of it being transported in jugs in the trunk.
Name:	8-24-2013 10% 25% & E85.jpg
Old 08-25-2013, 04:38:25 PM
BobRR BobRR is offline
Default Re: E15 Ethanol
Even though my truck is flex fuel I don't burn it often. Nest time I can afford to go on vacation I'm going to use it when ever available. Just to see the difference. I did notice the e-85 pumps say contains more then 51% ethanol instead of 85%. Bob
The Following User Says Thank You to BobRR For This Post:
  #63
Old 08-25-2013, 07:01:05 PM
Just realized I left out that the pumps that have the 51% on them are here in Michigan. Bob
Old 09-18-2013, 07:08:47 PM
ron17571
I was on a government site a while back and it stated that ethanol as a percentage would just keep increasing to 75 percent.
Old 09-19-2013, 12:23:55 AM
Ron never happen nothing would start in the winter on 75% that's why pumps here say 51% up to 85% in winter it drops to 51% and goes up in summer. Bob
Old 09-25-2016, 11:10:37 PM
Festus 42 Festus 42 is offline
I've tried up to E30 in my Jeep Cherokee, mileage dropped a bit but low and mid-range torque improved noticeably.
I'd like to know if the ECU advances the timing at all running a higher octane fuel, I could make up some or all of that mileage.
The Following User Says Thank You to Festus 42 For This Post:
  #67
Old 09-26-2016, 06:54:19 AM
oldtractors's Avatar
Some do. They will advance the timing up to a point, then back it off until the knock sensor quits. They will also richen the mixture up based on what the oxygen sensor sees, up to the limit of the injector. I get a check engine light after about E40, because of lean fuel mixture. I see no loss of mileage up to about E20 or so.
Jim Evans
Think ethanol is new? 73eldo Hit & Miss Gas Engine Discussion 9 01-12-2013 03:45:44 PM
IHC LB on E-85 Ethanol? dasselsmok Hit & Miss Gas Engine Discussion 13 05-09-2012 10:03:08 AM
Ethanol in the gas we buy... ronny p 148 Small Air Cooled Gasoline Engines 36 04-11-2011 10:38:56 AM
E85 Ethanol in old engines JAYPF Hit & Miss Gas Engine Discussion 9 01-04-2008 12:35:41 AM
