possible to drill hole through a roller bearing race?
this thread has 29 replies and has been viewed 10144 times
Old 10-23-2013, 06:55:41 AM
Default Re: possible to drill hole through a roller bearing race?
I have run this for several hours and no grease leaks from the bearing.
That AC seal, the rubber on the end is made from a standard seal type rubber. When I tested it by spinning it on the pulley shaft end with the drill I could tell it would hold up. I was worried it would be too tight as it created some heat from friction. And the seal lip was mostly unaffected. (idea was to wear it down a little for a better fit and also test it)
Regarding the old seal its surface had completely worn away so no sealing at all and was functioning more like a shielded bearing.
What I wonder is what application that AC seal is actually for? I have a 1994 Roadmaster and it uses those metal type seals for the compressor hose port, but it might use the bigger ones. That seal pack had 2 sizes of this seal.
I had called a pump company Depco pumps and they have rebuilt these old Onan pumps using a new bearing and a new type mechanical seal. There quoted price was $550.
You CAN buy a new water pump seal for these. The exact fit is a PS-163 from US Seal Mfg. and it costs $7
Old 10-27-2013, 01:05:59 PM
Lars Lars is offline
Although it sounds like the deed is already done, for your information it is possible to drill through a race or in some cases, even a ball bearing. It is called red point drilling. Create a flat spot on the race, and use a good carbide drill bit, and a drill press in overdrive as fast as it goes. Keep in mind that I have never done less than 3/16 inch in this process. Everything solid and square, start the contact and begin increasing pressure until the heat increases to the point that the race actually begins to penetrate. The shavings will be super hot and sharp as carbide burr grindings. Once the penetration starts, it must continue until through. Otherwise the race rehardens and is difficult to change bit angles and restart. Judgment and consistency is paramount. Nasty burr may develop in the inside.
Old 10-29-2013, 10:44:46 PM
KevinGWeq KevinGWeq is offline
I dont know if these would drill a bearing ??
But none the less some pretty impressive bits
http://youtu.be/dTGB9Od0ND0
Kevin
Old 10-30-2013, 10:17:51 AM
Dick Bauer's Avatar
Dick Bauer Dick Bauer is offline
Have you thought about drilling the shaft with a cross connector hole between the bearing? Just a thought.
Old 10-31-2013, 03:12:05 PM
I would like to see a center punch faze a bearing race. A cobalt bit will do a good job in a plow bolt. Races can be penetrated with a good masonry bit using red point, but the weak point is the silver solder surface area. A balanced diemaker bit is ideal with or without spirals. Straight shank works fine here.
Old 10-31-2013, 04:10:37 PM
He could always take it apart again and have a hole popped into it with EDM.
Old 11-03-2013, 08:39:54 PM
Dwayne Oxford Dwayne Oxford is offline
You can drill races with masonry bits. Need to grind a small flat to get started and be clamped down in drill press. When the point breaks thru you have to be real judicious on downforce. If you hang it' it'll shatter.
Old 07-01-2017, 06:34:37 AM
Updating this old bearing repair.
It is still working fine.
The Following User Says Thank You to sdowney717 For This Post:
  #29
Old 07-09-2017, 12:53:18 AM
tdmidget tdmidget is offline
So you went through all this crap and annoying everyone to avoid a $7.00 seal?
Old 07-09-2017, 11:44:58 AM
So...Almost four years and no problems - sounds like you got it. How much run time and how much time in the water?
On an unrelated question - how do these engines put up with salt water run through them all the time?
I, for one, was not annoyed - always like reading about someone pulling of a successful fix with what's on hand.
Best fix for spun bearing race? 55gasser Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 05-20-2012 03:57:57 AM
You think that it is easy to drill a hole in a piece of brass! Ronald E. McClellan Machine Shop and Tool Talk 21 09-11-2011 05:16:52 PM
Tapered Roller Bearing Adjustment Rex Piekarczyk Machine Shop and Tool Talk 1 11-19-2009 10:52:43 PM
Should I drill a hole? (cracked hopper) Jim H Antique Engine Archives 8 12-24-2002 07:33:09 PM
How to Drill a Hole?? WILL Antique Engine Archives 26 02-26-2002 12:00:13 PM
