"Mystery" spring in Wico C
this thread has 2 replies and has been viewed 1081 times
Old 01-01-2014, 07:14:11 PM
Ultrasport Ultrasport is offline
Default "Mystery" spring in Wico C
Can anyone tell me what the little coil spring, behind the disk that is behind the impulse mechanism is for. (terrible sentence, I know) It is in a little well and from the looks of the disk, at one time, there was something contacting the dick, maybe a brush pushed bu the spring? The spring has a loop in the end so I'm not sure what it was supposed to do or if it's necessary. There is nothing there but the spring now and I'm wondering what to do with it.
Thanks in advance,
Steve
Old 01-01-2014, 08:52:38 PM
Mitch Malcolm Mitch Malcolm is offline
Default Re: "Mystery" spring in Wico C
Steve that spring had a little rectangular piece of Formica or something like it anyway it scraped oil off of the flat washer to oil the bushings you can make one easy..
Old 01-01-2014, 08:55:11 PM
Thanks Mitch, That makes sense.
I appreciate the help,
Steve
Winter "fix" of Old Iron till Spring Motormowers Small Air Cooled Gasoline Engines 7 02-16-2011 05:35:15 PM
Blackstone "Carters Patent" spring injection engine help WilliamInOz Smokstak Down Under 2 07-12-2010 10:13:39 AM
Replacing spring on FM "ZA" hand crank Karl T Schwab Hit & Miss Gas Engine Discussion 1 09-16-2007 07:45:51 PM
Whats the "spring thingie" called on a Webster Roo Hit & Miss Gas Engine Discussion 6 11-24-2005 06:24:29 AM
! Mystery Solved ! " Shipman Engine " Tim Burke Steam Stationary Engines, Traction Engines 0 01-20-2004 07:42:56 PM
