f350 power steering pump question
this thread has 5 replies and has been viewed 2354 times
Old 03-01-2014, 06:08:24 PM
Default f350 power steering pump question
Quick question in regards to the power steering pump on my 1978 F350 with 400 m engine.
Everything works fine if I add fluid.But it leaks out quick because the plastic reservoir is loose on the pump.Best I can remember there is a big oring on there to seal it.But what holds the reservoir to the pump?I need to know because if I need a pump to fix it I have to order it and I dont want to tear it apart until I have parts on hand.But if it is just a bolt gone or something,maby I can repair it.
Old 03-01-2014, 07:14:28 PM
Nick's Avatar
Nick Nick is offline
Default Re: f350 power steering pump question
The fitting for the high pressure line holds it on. It's got a hex for a wrench. Take that off and the reservoir will slide off. Pretty simple task but if y'all need some help you're welcome to bring it over here.
Old 03-01-2014, 11:31:56 PM
Ok,well there is a issue because the tank just wobbles around on there.I will have to unbolt the pump and see why.May be cracked and not able to stay tight on the pump.That is my first theory now for sure.
Old 03-01-2014, 11:47:25 PM
Check but I am pretty sure yours calls for type 'f' tranny fluid in the PS system. no point in buying high priced power steering fluid when it leaks....
Old 03-02-2014, 01:01:13 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Those plastic reservoirs tend to disentigrate with age and sometimes swell and not fit properly. I've had one that always leaked no matter how many times it was resealed, the only fix was to go get a new complete unit. F.J.W.
Old 03-22-2014, 10:32:51 PM
Well I am king of the titewads.
I took a look at this problem yesterday and bought a 4-6 inch hose clamp at the hard ware.
I put it around the resevor about a 1/4 inch back from the edge of it towards the pulley
I really tightened it down good. Then checked for slop and there was none.
I put fluid in it and drove it a bit and no leak!
power steering peter1020 Antique Farm Tractors 6 09-12-2013 03:15:16 PM
Power Steering -W-9 Wayne Riedlinger Antique Farm Tractors 4 05-11-2013 05:30:30 PM
John Deere Power Steering Pump JohnDeere80 Antique Farm Tractors 11 01-29-2013 09:35:40 PM
Power steering TheEngineGal Antique Autos and Trucks 25 11-19-2008 07:28:29 PM
Power steering Ihorse Hit & Miss Gas Engine Discussion 7 10-25-2005 02:51:47 PM
