#22 Sumpter
this thread has 4 replies and has been viewed 1319 times
Old 04-07-2015, 09:59:25 PM
GlenK GlenK is offline
Default #22 Sumpter
Can someone give me the measurement center to center on the mounting holes on a #22 sumpter . The 2 that mount the mag to the engine . Thank you , Glen
Old 04-09-2015, 08:44:50 AM
Default Re: #22 Sumpter
Does the #22 have the same mounting spacing as the #12 ?
Old 04-16-2015, 06:39:04 PM
Chuck Hall Chuck Hall is offline
Yes, both mags have the same bolt spacing. What engine are you working on? Sounds like a Fairbanks Morse 3 or 6 hp igniter engine. I have a Sumter # 22 on my 3hp, and a Sumter # 25 on my 6 hp engine.
---------- Post added at 06:39 PM ---------- Previous post was at 06:25 PM ----------
Hi Glen, I just realized I talked to you earlier about Sumters. How are you coming along with it?
Old 04-16-2015, 10:10:09 PM
Chuck , I'm just trying to bring some dead mags back to life . For health reasons I can't work anymore , so I thought I would give it a try to keep myself from going goofy- er . I am learning a lot , some of what to do and some of what not to do . Thanks for the information . I am going to make a base plate for the #22 . I have made some for the #12 .
Old 04-18-2015, 08:42:02 PM
Glen,
I have swaped mags on my engines and the bases are different to compensate for the magnet size and so on. but the bases seem to fit nicely. In other words I took a # 12 off my 3 hp and put on a # 22 from my 6 hp and put a # 25 on the 6 hp. So I got a spare # 12 for a headless. I don't have a headless but I got the mag. My engines seem to run just fine. Keep in mind all the mag gears are different. That is the key right there. Anyway great to have you on board. We need mag builders in the hobby.
Sumpter #12 Timing Jim Gorter Magnetos, Ignition Coils and Spark Plugs 3 05-04-2011 02:15:23 PM
Sumpter # 12 mag. Roger Kirschenman Magnetos, Ignition Coils and Spark Plugs 2 10-30-2009 11:04:19 PM
Sumpter # 14 mag. help Morganr Hit & Miss Gas Engine Discussion 3 05-30-2007 07:40:45 AM
Sumpter 12 mag BobRR Hit & Miss Gas Engine Discussion 4 03-31-2006 08:13:53 PM
Sumpter No 12 Mag Vic Pankoski Antique Engine Archives 0 07-02-2003 09:54:52 AM
