Webster AK and K magneto differences
this thread has 7 replies and has been viewed 2057 times
Old 05-17-2015, 06:53:55 AM
BV071747 BV071747 is offline
Default Webster AK and K magneto differences
I have a 2 ˝ hp Rock Island. It has a Webster mag stamped AK. I see a lot of type K mags around and wonder what the difference is. Can the type K be used in place of the AK. It would be great to find some literature that told all the difference in the Webster mags
Old 05-17-2015, 09:21:15 AM
Mitch Malcolm Mitch Malcolm is offline
Default Re: Webster AK and K magneto differences
They are the same the original mag when it came from Webster was stamped with the K-- for the application it was intended for The AK or BK stamp is a replacement mag the first letter designates wether the starting handle tripped from the left or right .
The Following 2 Users Say Thank You to Mitch Malcolm For This Post:
Old 05-18-2015, 09:31:21 AM
Thanks Mitch – Now let me make sure I have this correct. There is a K on e-bay right now. The push finger on the mag appears to be set up for a left to right trip. My Rock Island trips from the right to left. Can I just turn the push finger over or do I need to get another push finger.
Again Mitch, thanks
Bruce
Old 05-18-2015, 09:53:38 AM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
You cannot turn it over because it is tapered fit.
The Following User Says Thank You to Steve Kreiner For This Post:
Old 05-18-2015, 11:32:43 AM
You would need a left hand trip finger a K3 I think and would have to turn the armature shaft end for end. to make that mag work on a left hand engine meaning the mag is on the left side of the engine tripping from the rear.
The Following User Says Thank You to Mitch Malcolm For This Post:
Old 05-18-2015, 12:20:04 PM
Thanks Steve and Mitch.I Appreciate the information. I'll make sure I order the correct part so it will work on my engine. I decided I better order the Doc Shuster book "The Webster System" I need to better understand the mags in general
Bruce VB
Old 05-18-2015, 12:23:49 PM
Mitch proably has the trip finger he is a sponsor here.
Old 05-26-2018, 04:33:30 AM
EMU EMU is offline
Cool Re: Webster AK and K magneto differences
My Webster Tri Polar magneto is stamped K 90 , what would this mean .?
---------- Post added at 06:33:30 PM ---------- Previous post was at 06:30:52 PM ----------
It also has stamped above serial number T 387
Boshch BAI magneto differences joder Magnetos, Ignition Coils and Spark Plugs 0 04-29-2014 09:59:36 AM
magneto differences joder Magnetos, Ignition Coils and Spark Plugs 0 04-29-2014 09:47:49 AM
Webster 2 bar magneto Roger Eldred Magnetos, Ignition Coils and Spark Plugs 2 09-11-2005 01:04:24 PM
wEBSTER MAGNETO HELP LarryH Antique Engine Archives 2 06-24-2004 02:19:17 PM
Webster Magneto Lynn Nelson Antique Engine Archives 2 01-09-2000 09:03:31 PM
