1/2 pipe thread plug adapter
this thread has 12 replies and has been viewed 2119 times
Old 01-03-2016, 01:51:26 PM
Walter Neumann jr Walter Neumann jr is offline
Default 1/2 pipe thread plug adapter
I was considering building some adapters so you can take an ordinary plug and thread it into 1/2 hole. has any one else done this and what were your results? what common plug would you use? ive seen some for sale some where but its nice when you can make your own, its also getting tougher to find plugs.
Old 01-03-2016, 03:12:28 PM
gootsch gootsch is offline
Default Re: 1/2 pipe thread plug adapter
30 years ago, listed in the back of the Champion spark plug catalog were adapters to reduce the thread size of spark plugs from no longer available heat ranges and thread sizes to 14 mm threads and N thread lengths which were available in a wide variety of heat ranges and grounding electrode styles. We used them in Rotex snowmobile engines. They worked well. I do not remember what the length of N threads is but I think it is 3/4 of an inch.
The Following User Says Thank You to gootsch For This Post:
Old 01-03-2016, 07:25:57 PM
Tom G Tom G is offline
Go to the hardware store and buy some pipe bushings which reduce 1/2 inch male down to 1/8 inch female. Drill and tap the 1/8 female hole for a 14 millimeter spark plug. Easily done.
The Following User Says Thank You to Tom G For This Post:
Old 01-03-2016, 08:38:38 PM
DustyBar DustyBar is offline
Why not just drill and tap a 1/2" pipe plug. Might have to look for a solid pipe plug and not a thin cast plug to make sure there is enough material to thread.
The Following User Says Thank You to DustyBar For This Post:
Old 01-03-2016, 09:07:55 PM
Dusty and tom I was thinking something like that. I also was thinking of making a pair for the old faithful hart parr. I think it uses a champion 34 don't remember if those are 3/4 or 7/8 pipe thread. I'm no where near the tractor its an hour from me maybe somebody can confirm for me it would save me a trip. Ideally we have talked about converting it back to ignitors if anyone. Has a line on parts or if we could borrow to reproduce let me know. But for now we will just run buzz coils.
Old 01-04-2016, 12:35:57 PM
flathead jim flathead jim is offline
Autolite still makes 1/2 inch pipe thread spark plugs part # 3095 i just bought some at advance auto parts for $2.19 each.
The Following 3 Users Say Thank You to flathead jim For This Post:
Old 01-04-2016, 12:50:42 PM
David Babcock David Babcock is offline
Smile Re: 1/2 pipe thread plug adapter
Those adapters are available somewhere. I bought some a few years ago and used them in my 28-50 hart parr. They seemed to work ok. But i thought the plugs-adapter combination looked terrible. I figure if you have a nice old tractor or engine, why make it look cheap with these adapters as about any plug you want is available new or used. Just my thoughts. I kinda like keeping everything correct if possible. Thanks.
The Following User Says Thank You to David Babcock For This Post:
Old 01-04-2016, 06:42:23 PM
I agree david what im more worried about is function more than beuty it suck when your in a middle of a demonstration and no parts to be had. this is more for a backup
Old 01-04-2016, 06:52:11 PM
Pipe plugs tend to have a squared off top to grip with a wrench. Get a pipe bushing which has a nice flat top and is already drilled down the center. This gives you a good guide hole to start with. You merely enlarge this hole and tap it. BTDT years ago. Get a good quality pipe bushing with a smooth finished surface, and not some of those rough cast Chinese pieces of junk.
A fellow with access to a good machine shop could turn out an adaptor from scratch. The average guy can buy a pipe bushing, and most of the work is already done. The average guy can make all of the adaptors that he wants if he can drill a hole and turn a tap with a wrench. Keep it simple.
The Following 2 Users Say Thank You to Tom G For This Post:
Old 01-05-2016, 10:16:31 AM
Steve Kunz's Avatar
From what I understand the 14mm spark plug thread is a special pitch at 1.25mm and a regular 14mm tap is 1.5mm pitch??
Here is a link for premade one's for model T Fords.
https://www.modeltford.com/item/14MM-AD.aspx
Steve Kunz
The Following User Says Thank You to Steve Kunz For This Post:
Old 01-05-2016, 03:07:58 PM
at 15dollars a set they are not worth making
Old 01-06-2016, 10:41:56 PM
Available from Sears. What's your problem?
http://www.sears.com/irwin-hanson-vi...2&blockType=G2
Old 01-09-2016, 12:22:11 AM
cobbadog cobbadog is offline
Hi Steve Kunz,
with the metric pitch both 1.25mm and 1.5mm are standard options, I have them both for many different sizes in my garage.
It is like the different of UNF & UNC or BSF & BSW it is a coarse and fine thread option for different applications.
Hope this helps.
pipe thread cutting TomBall Machine Shop and Tool Talk 18 07-25-2015 01:07:19 PM
3/4 inch pipe thread spark plug REB37E Magnetos, Ignition Coils and Spark Plugs 10 07-23-2014 08:42:16 AM
Spark plug adapter... Jim Sherman Hit & Miss Gas Engine Discussion 1 11-06-2011 02:35:59 PM
Adapter to go from 1" pipe thread to regular exhaust pipe? LombardiniDiesel Small Air Cooled Gasoline Engines 2 02-07-2011 12:15:00 AM
PRIMING CUP 1/4 inch pipe thread Eric McKenna Hit & Miss Gas Engine Discussion 3 07-24-2010 09:35:16 PM
