David Bradley Super 600 maintenance question
this thread has 2 replies and has been viewed 1410 times
Old 01-03-2016, 06:53:49 PM
R Davis R Davis is offline
Default David Bradley Super 600 maintenance question
The manual says to put 4 or 5 drops of #20 oil twice daily on clutch shifter blocks, but doesn't say anything about lubricating the bronze bearing in the clutch pulley. I can also get oil in on the clutch's ball bearings, will that work its way down to the bronze bearing or do I need to do something else?
The 600's a beautiful machine, but I feel like it should also be used for its intended purpose as long as there's plenty of TLC. Anyone familiar with what I'm asking? Thanks...
Old 01-09-2016, 08:07:09 PM
ca1912 ca1912 is offline
Default Re: David Bradley Super 600 maintenance question
I take the clutch pulley off and put just enough oil on the brass bearing so that it has enough oil to reduce wear. If you use to much oil, it will get on the clutch facings and cause it to slip. About 2 to 3 drops of oil should work.
The Following User Says Thank You to ca1912 For This Post:
Old 01-10-2016, 08:08:26 PM
Thanks, I was beginning to think I was the only one here who owns a Super 600...lol
David Bradley 83130 question Dean Richards Chain Saw Collectors 1 02-17-2013 08:56:21 PM
David Bradley - Super Power Ken Karrow Garden Tractors and Mowers 5 12-22-2009 08:27:33 AM
Newbie Question: David Bradley Diesel? zerochance Garden Tractors and Mowers 2 10-07-2009 09:01:35 PM
David Bradley "super power" AU8 d0n H Antique Farm Tractors 1 07-24-2008 08:03:50 PM
David Bradley Super 3 ? M. Schaub Antique Engine Archives 0 08-24-2003 06:34:21 PM
