Super C Hydraulics Question
this thread has 2 replies and has been viewed 629 times
Old 10-30-2016, 04:44:21 PM
madscotsman59 madscotsman59 is offline
Default Super C Hydraulics Question
On my Super c the hydraulic lines run from beside the pump control over top of the floor board to a square block mounted in front of the toolbox/seat then separate hoses run underneath the box to the three point lift ram. Since i'm installing a cab i need to reroute the lines under the floor and want to get all new hoses that need to be longer. My question is: Do i still need that box that was bolted to the floor pan? is it a equalizer/mixing valve or anything related to the pressure? I'd like to eliminate it if possible. Thanks.
Old 10-30-2016, 06:39:58 PM
Default Re: Super C hydraulics question
I think that block contains a double acting check valve. It's main purpose would be to carry the pressure of the 3pt load instead of having the control valve handle it. There is less chance of leak down with the check valve.
The Following User Says Thank You to Mark Schneider For This Post:
Old 10-31-2016, 10:23:51 AM
So i should keep it inline? O.K. I think what i'll have to do is just reinstall it under the floor and add length to the back two hoses to reach the back lift ram. I Had a feeling the block served a purpose, but i wasn't sure. Thanks
My Super C Paint Question madscotsman59 Paint Shop 8 06-19-2019 10:59:29 AM
David Bradley Super 600 maintenance question R Davis Garden Tractors and Mowers 2 01-10-2016 08:08:26 PM
Oliver Shop Manual Model 99- super 99 & super 99GM free download TractorDom Service Manual Scans 0 11-26-2015 01:49:22 AM
Hydromac 8A Hydraulics Question rhb-3 Lifting and Loading 1 12-26-2014 02:16:09 PM
Farmall Super A? Question Firewoodguy Antique Farm Tractors 12 05-04-2011 09:25:22 PM
