Van Norman 777S4
this thread has 25 replies and has been viewed 2816 times
Old 05-31-2017, 08:19:06 AM
Default Re: Van Norman 777S4
Originally Posted by storm View Post
another question is the shaft on the 777s4 bar thicker than a 777.mine measures about 2 1/2.theres a reason for this question as i ordered a short bit holder for a 777 thinking its the same now im wondering.
The column on the 777(s) is a little over 2˝" in diameter. The small tool holder is for bores of 2.55" - 4.00"; the large tool holder is for 4.00" - 5.35".
What is your concern?
Old 05-31-2017, 09:45:35 AM
I think there are two different size cutters for the small machines, the 888 takes an even larger one. I thought the 944 & 777 used different cutters, but I've seen large and small on either, not talking about length, the receptacle is different. The cutter heads may be interchangeable, not sure.
Old 06-02-2017, 12:28:30 PM
storm storm is offline
i got taken what else is new this thing doesnt cut past about 3 inches.if i had a longer screw it might cut 3.3 buyer beware on ebay i should have known better.this thing is only 1.25 long anyone know the lenght i need.the one i have is 2.25
Old 06-03-2017, 06:59:30 AM
is it possiable just to buy a longer screw to make this work and if so how long.you do need a cutter this short to bore 2.55 bore.it says nothing about different screws i my operation manual.
Old 06-03-2017, 03:28:41 PM
There are different length cutter blocks, too short overextended will chatter.
Old 06-03-2017, 07:18:49 PM
i know there are different holders i only want to know the one in my operators manual with number 777 7177.i have 178 which is 2 1/4 inch.what do they do with this 177 to make it cut 2.55 to 4 inch.seems hard to believe.
Van Norman 777 or 777S Longshot1 Machine Shop and Tool Talk 0 02-19-2016 11:11:24 PM
Van Norman 777 and 777s Longshot1 Machine Shop and Tool Talk 3 12-14-2015 09:15:42 PM
Van Norman 944 Davo Grunt Machine Shop and Tool Talk 3 03-04-2010 09:43:07 AM
