Milling attachment for lathe
this thread has 3 replies and has been viewed 1093 times
Old 06-12-2017, 07:58:06 PM
Bryant Bryant is offline
Default Milling attachment for lathe
I thought this was for a heavy 10 but is to small. Anyone know what it fits?
ID:	284284   Click image for larger version
ID:	284285   Click image for larger version
Old 06-12-2017, 09:24:14 PM
JoeCB JoeCB is offline
Default Re: Milling attachment for lathe
Not Atlas. Atlas has the post on the cross slide, only a bored socket in the compound or for a milling attachment.
Joe B
The Following User Says Thank You to JoeCB For This Post:
Old 06-12-2017, 09:36:48 PM
Mike Monnier's Avatar
Hoarder
Maybe a 9" South Bend? I have some odds and ends tooling that came with my 10K that has a similar design.
The Following User Says Thank You to Mike Monnier For This Post:
Old 06-13-2017, 07:51:06 AM
Travis McCoy Travis McCoy is offline
I'm guessing it is at least partially home built. I built a similar attachment for my 9" South Bend, but the little stub at the bottom was machined with a taper to accommodate the compound locking bolts. It was done that way to keep the compound from trying to rise up under pressure.
With that said, it looks like it might easily fit a 9" south bend. The Atlas 10F I had was the same set-up only reversed, meaning that the cross slide had that stub on it and the compound had a hole in the base to receive it.
Travis
The Following User Says Thank You to Travis McCoy For This Post:
Milling machine Jerry B Machine Shop and Tool Talk 14 11-30-2015 01:54:02 PM
milling attachment Jerry B Machine Shop and Tool Talk 1 03-10-2015 08:12:46 PM
Unknown Lathe/milling combo Thiel Machine Shop and Tool Talk 9 03-13-2012 04:25:11 PM
Atlas Lathe Attachment, What Is It? Junkologist Machine Shop and Tool Talk 1 05-14-2010 04:04:09 AM
CNC milling John Herald Antique Engine Archives 3 09-08-2003 09:38:37 PM
