Power feed; the ultimate lazy man addition
this thread has 0 replies and has been viewed 798 times
Old 06-19-2017, 05:10:39 PM
Default Power feed; the ultimate lazy man addition
It was a bit of work to install this ebay $200 chinesium Bridgeport feed to my small mill but well worth it. Re machining the lead screw to get things within .0005 was a challenge as the screw is longer then my lathe. Then a few mounts for the drive and an end cover had to be fabricobbled. But is this thing a hand saver! Servo drive with 150 inch pounds of torque, ( don't need 1/10th of it) and adjustable speed from zero to waay fast. Of course as it's Chin, it makes more noise in one direction than the other as something in the guts isn't round. But it is quieting down with use.
Bridgeport 6F-B Power Feed Motor Rbruner45 Machine Shop and Tool Talk 3 02-07-2017 06:24:32 PM
Detroit Lubricator No. 22 3-feed - sight feed glass scsshaggy Steam Stationary Engines, Traction Engines 5 02-24-2016 09:34:04 PM
The Ultimate Solution... OTR Generac Generators (SEARS, etc.) 2 12-24-2014 01:13:39 PM
Ultimate Buggy Fred Van Hook Hit & Miss Gas Engine Discussion 10 10-18-2005 10:34:11 PM
