How to Tighten Pipe
this thread has 8 replies and has been viewed 1777 times
Old 06-24-2017, 11:18:46 PM
ronny p 148 ronny p 148 is offline
Default How to Tighten Pipe
I had some 1/4 inch stainless tried to use strap wrench would not grip the pipe Finally use small pipe wrench . If I wanted to tighten pipe brass etc. and not leave wrench marks for polished or any other undamaged look how do you accomplish this task and have it not leak due to not enough torque ?
Ronny
Old 06-24-2017, 11:22:12 PM
Default Re: How to tighten pipe
Use an internal wrench, I've got a few around here, somewhere, have never needed them, yet.
Old 06-24-2017, 11:33:21 PM
I'm surprised the pipe wrench got ahold of the 1/4 SS pipe. I've always struggled with the smaller SS piping.
Old 06-24-2017, 11:43:24 PM
Power Power is offline
I have a strip of bicycle inner tube for that. I wrap cleaned grease & oil free pipe with it, then strap wrench.
The Following 2 Users Say Thank You to Power For This Post:
Old 06-25-2017, 12:37:16 AM
Troll's Avatar
Troll Troll is offline
Default Re: How to Tighten Pipe
I've seen rubber lined clamp wrenches used for this at both Grumman, and McDonnel-Douglass. The wrenches were specific to the sizes of tubing however and probably not cheap. They worked sorta like a take apart piston ring compressor with an over center cam action to close and apply tension to the tubing.
Old 06-25-2017, 06:48:02 AM
Doug Kimball's Avatar
Use a Parmalee pipe wrench .... No.1 set 1/4" to 1" & No. 2 set 1" to 2". I bought mine at a yard sale several years ago. Recently bought #1 & #2 for a friend for $30 at a flea market. New they are prohibitively expensive; used on Ebay are also pricey.
ID:	285151   Click image for larger version
In Kennebunk, Maine;
Doug Kimball
The Following 2 Users Say Thank You to Doug Kimball For This Post:
Old 06-25-2017, 06:52:48 AM
Glenn Gieszler Glenn Gieszler is offline
Chain wrenches do work, however having a selection of sizes that best fits the application is a requirement
You can google vice grips, the picture shown is a secret tool used to prevent the marring of shafts along with a strap wrench when repairing rotary burners that I use, there are several sizes available
Old 06-25-2017, 08:53:43 AM
ronm ronm is offline
Those vise grips were intended for rounded-off hex nut removal, they grip 3 sides of a hex. I have a set of them too, & they work, other than they're too thick to get into a lot of places where you need them...but yeah, they do work for gripping round things too...
Smokstak member #442
Old 06-25-2017, 01:05:46 PM
SLIP KNOT Ya it worked but left marks was not issue was just drain for my compressor . Why don't they put decent 1/4 turn valve on them so you don't have to lay on floor to reach it ! Plus cheap screw valve was painted shut wouldn't have worked anyway . Just wanted to know how you all do it for future projects that I want to jaw marks on.
Ronny
Model Pipe, Pipe Wrench - no marks left Paul Spence Scale Model Engineering 12 10-23-2018 11:49:02 AM
Adapter to go from 1" pipe thread to regular exhaust pipe? LombardiniDiesel Small Air Cooled Gasoline Engines 2 02-07-2011 12:15:00 AM
Working with pipe and pipe threads? Bob Krummel Hit & Miss Gas Engine Discussion 12 03-19-2010 08:59:34 PM
Old pipe fitting found on an old pipe Paul Spence Hit & Miss Gas Engine Discussion 0 01-11-2010 03:56:27 PM
Loose press fit - how to tighten up? Don Naismith Hit & Miss Gas Engine Discussion 7 05-25-2009 09:58:40 AM
