Power prod.Breaker Point Cam,Can anyone make one?
this thread has 7 replies and has been viewed 1015 times
Old 06-27-2017, 05:25:34 PM
thefixer thefixer is offline
Default Power prod.Breaker Point Cam,Can anyone make one?
hi all, Working on a Power Prod 2 stroke and the Break Points Cam is broken.
So far I haven't been able to find a replacement..which seems very strange.
I'm wondering...Can anyone here make one for Me?
The orig looks to be cast. then Machined.prob why it broke.
Not looking for a freebe..I will pay for your time.
thanks!
Old 06-28-2017, 04:09:47 PM
Default Re: Power prod.Breaker Point Cam,Can anyone make one?
Have you considered something like this?:
https://www.amazon.com/ELECTRONIC-TR.../dp/B007BI6FW6
There are many models of this available. That one was just to give you the idea, if needed.
That cam looks like it might have been sintered (compressed from powdered metal, not cast.
Pete Stanaitis
Old 06-28-2017, 06:36:15 PM
flywheelphil flywheelphil is offline
What model Power Products engine are you working on?
Old 06-28-2017, 07:13:19 PM
Pete, Thanks for the Link....that's a good option.
Sintered eh?.....I understand...yeah the material looks very odd.
Flywheel,..maybe I'm not looking in the right place for a Model number but,all I found was a Tag that says: T 616 14
2653049
thanks Fellas!
Old 06-28-2017, 10:53:39 PM
slip knot slip knot is online now
I've got a little power products hedge trimmer out in the shop. its got too many issues to rehab but I can look and see if the points cam is ok.
Old 06-29-2017, 10:11:32 AM
Can you post a picture of the engine ?
Old 06-30-2017, 10:03:20 AM
You might still be able to get new parts.
Yesterday I googled "power products engines" and found that that name was associated with Lauson, purchased by Tecumseh, etc. Anyway, there seem to be a lot of folks out there who play with those engines.
Here's one particularly interesting thread:
http://www.yesterdaystractors.com/cg...oolt&th=108856
But to answer your original question: "Can anyone make one?" :
we have made some in the past of a more complex design, but it's a lot of work. We cast about a dozen cams from an original, but in bronze and then machined them to specs. But it took a fair amount of fixturing. Even had to make a degree wheel setup to verify points lift in relation to some teeth on the cam that attached to a centrifugal (sp?) timing adjuster.
Long story short: It can be done, but I don't think I'd do it again.
Pete Stanaitis
Old 06-30-2017, 11:47:11 AM
Hello Pete...Thanks for Your input and the info......Just exploring the Options...but I knew it is a lot of work..An old Friend of mine was a machinist for many years.
I understand about the timing as well.....I have another PP Engine that has a totally different Ign set up...The Cam fits on the shaft of the one I'm trying to repair but,the Cam Lobe is an entirely different profile.
old Craftsman/power prod Points Cam broken.what model? thefixer Small Air Cooled Gasoline Engines 16 08-29-2017 06:23:35 PM
4A032 point breaker assembly opus Military MEP and Aircraft Gen-Sets 1 10-12-2013 05:41:42 PM
Onan 30EK will not make power hogfan1967 Onan Generators 3 11-04-2009 09:08:43 AM
Badly stuck Briggs 5s Breaker Point Plunger James Wallace Small Air Cooled Gasoline Engines 3 11-07-2008 06:37:58 PM
Lunkenheimer Co. & Hale Oilfield Prod. Russell Farmer Oil Field Engines & Related Equipment 0 01-16-2006 09:00:54 PM
