'27 John Deere "D" timing w/Eisemann mag
this thread has 1 replies and has been viewed 734 times
Old 06-30-2017, 11:10:28 AM
Jamac Jamac is offline
Default '27 John Deere "D" timing w/Eisemann mag
Can someone explain the procedure for timing an Eisemann Mag (K15970) to a 1927 John Deere mod. "D" tractor.
Thanks,
Jamac
Old 06-30-2017, 09:26:16 PM
Gene Williams Gene Williams is offline
Default Re: '27 John Deere "D" timing w/Eisemann mag
I am sure there is a better way but I simply put the #1 cylinder on top dead center, just fire the magneto and attach it to the engine without moving either the engine or the mag. Adjust the jaws of the coupler until the mag can be slid in without turning it. It is really simple and works every time. Before trying to start the tractor,
be sure to slowly roll the engine through noting where it fires just in case something is off a bit.
The Following User Says Thank You to Gene Williams For This Post:
1950 John Deere "B" Runs on One Cylinder 207tom Antique Farm Tractors 10 07-15-2016 10:09:27 PM
1941 John Deere B, "HOLLYWOOD B" Full Exhibition Hollywood B Smokstak Forums Meet and Greet 1 04-14-2015 09:43:17 PM
Timing "Wico C" on a John Deere B (1942) jwhitmor Magnetos, Ignition Coils and Spark Plugs 5 11-15-2013 11:49:43 AM
Help!! I need some advice on a John Deere slant dash "A" electrical system!! Brad73 Antique Farm Tractors 5 08-10-2012 09:03:44 PM
John Deere "Patio Series" Mowers Jonathan Widelo Garden Tractors and Mowers 1 08-02-2005 01:26:11 AM
