American machine and tool co small lathe help
this thread has 4 replies and has been viewed 1004 times
Old 06-30-2017, 10:25:33 PM
MR.22 MR.22 is offline
Default American machine and tool co small lathe help
I don't know the model but is a 8"x24" lathe. I need to find a missing part. Attached is a picture. I really want to get this lathe going agin Thanks leroy
Old 06-30-2017, 10:31:04 PM
Default Re: American machine and tool co small lathe help
Here is picture of what is missing
Old 06-30-2017, 10:56:14 PM
Looks like you are missing the compound. Finding 1 for a fairly rare lathe might be tough. I would adapt another 1 from maybe a South Bend as they are common. Rob
Old 07-01-2017, 08:18:01 AM
It has the same mounting style as a 9" southbend as Rob stated. But you better check the dimensions before you buy a SB compound of of ebay.
Old 07-01-2017, 10:44:26 AM
I suggest taking some accurate measurements first.
Then contact a company that sells South Bend parts and tell them what you have found.
Here's one:
http://www.southbendlathe.com/older-machines/parts
You may not buy from them, but at least you might be farther along in finding what you need.
Depending on how much work you have to do, you might be able to cobble up a simple tool post/tool holder to go onto that dovetail. You wouldn't have a compound, but you could still do a lot of basic turning. After all, the engine lathe was once billed as the only machine tool that could make itself.
Pete Stanaitis
Lathe parting tool recommendations Dustin D Ehli Machine Shop and Tool Talk 24 01-22-2017 10:19:22 PM
Knurling tool for lathe Reed Engine Machine Shop and Tool Talk 15 01-01-2017 02:04:13 PM
Old American brand lathe locked up. Avery22x36 Machine Shop and Tool Talk 19 12-10-2016 11:29:24 PM
unknown lathe tool Edgar Machine Shop and Tool Talk 2 03-28-2012 12:13:37 AM
The Good Machine Company / American Roads Machine Jeff Smith Hit & Miss Gas Engine Discussion 0 04-15-2005 11:10:28 AM
