70's Hein Werner 12-A Bottle Jack Filling
this thread has 9 replies and has been viewed 2021 times
Old 07-15-2017, 06:52:29 AM
stm stm is offline
Default 70's Hein Werner 12-A Bottle Jack Filling
Greetings
This old jack still works though slowly>>>I bought some jack fluid and proceeded to fill it when I realized after 20 years that there are 2 chambers, a center column threaded screw and a bottom one the same size.
So with the center one topped off and the jack working now i opened the bottom one to find it empty.
How, do tell, is this unit supposed to be loaded? Or NOT?
stm
Old 07-15-2017, 12:20:02 PM
Default Re: 70's Hein Werner 12-A Bottle Jack Filling
Lay it down and fill it. Light motor oil, ATF or whatever you have. With the valve open pump it umpteen times to purge and burp air. Then drain a little bit out so it has some expansion space. You should be good to go then.
Old 07-17-2017, 07:04:37 AM
stm stm is offline
Appreciate your reply but what about the 2 chambers?
Old 07-17-2017, 07:21:54 AM
Never saw the guts of a HW jack although they were made 10 miles from me and some customers of mine worked there. Think of how they filled it at assembly.. Pics?
Old 07-17-2017, 05:59:34 PM
stm stm is offline
Default PHOTOS 70's Hein Werner
No mind the whiskey barrel. Only a few ounces left now.
Name:	hein werner 12 A 001.jpg
ID:	286696   Click image for larger version
Name:	hein werner 12 A 002.jpg
ID:	286697   Click image for larger version
Name:	hein werner 12 A 003.jpg
Old 07-19-2017, 02:16:40 PM
Dwayne Oxford Dwayne Oxford is offline
Default Re: PHOTOS 70's Hein Werner
Maybe double action? I'd put oil in the bottom to see what happens.
Old 07-19-2017, 02:35:30 PM
stm stm is offline
Inquired at a H-W associated biz which informs the fluid moves from top to bottom going up and revers when lowering. PRESUMABLY then both chambers should never be filled at the same time. PRESUMABLY.
Thanks Everyone!
Old 07-19-2017, 02:54:33 PM
Assuming the screw is the fill port, yeah, lay it on it's side and fill it.
Screw back in then open the valve and pump it 20-50 times. Then lay it back down and see if you can fill it more.
If the screw isn't the fill port take the valve out and do it.
Old 07-19-2017, 04:42:13 PM
stm stm is offline
Yep will note that for rainy day research. Presently going to pump up a corner of the house an inch however and hopefully
Best
Stm
Old 07-22-2017, 12:23:22 PM
I have several bottle jacks around here and never thought of filling a "second" reservoir.
I don't think that area is meant to be filled.
Pete Stanaitis
Air in manual bottle jack Dwayne Oxford Machine Shop and Tool Talk 19 11-23-2015 04:03:00 PM
Werner & Glaeser Domestic Coffee Roaster Sheboygan, WI Mike Paul Farm Antiques and Collectibles 0 05-24-2015 09:08:20 PM
Buda Railroad Bottle Jack Ratchet/Screw type - Repair trafficagent Machine Shop and Tool Talk 3 01-06-2014 06:10:04 PM
Any Hein Werner Porta-Power parts out there? Robt. Machine Shop and Tool Talk 4 06-23-2008 10:18:19 PM
