Geared hoist drum clutch
this thread has 0 replies and has been viewed 875 times
Old 08-09-2017, 07:05:55 PM
thmecharlie thmecharlie is offline
Thumbs down Geared hoist drum clutch
Geared hoist
I have Ireland machine and foundry hoist the drum shift fork rides in lower casting and is supposed engage upper shift collar but lacks nearly an inch. Upper fork is worn and barley engages shift collar. Lower collar is restricted by frame casting as to raising it. Thinking of removing shift arm bosses and making my own iron strap bolted on to fix it. I have nothing to go by not even a picture of working unit. Trying to rehab for Yankee winch for log skidding from inaccessible areas. Will be powering with 6 horse pedator engine with machined flat pulley. Any idea rating on this unit I know they made up to 3000 pounds, this has double gear reduction with 4.8 and 5 ratios not including drum size driven pulley is 12 inchs drive pulley is 2.25 inchs.
ID:	288287   Click image for larger version
Little Giant Geared Seeder, pat'1886 mschreiber Farm Antiques and Collectibles 0 08-13-2013 10:42:35 AM
Gantry hoist or A Frame Hoist treasurechest Machine Shop and Tool Talk 7 12-20-2011 02:13:52 PM
Pattin Bros. Geared Powers Patrick McNallen Hit & Miss Gas Engine Discussion 0 01-30-2007 09:05:19 PM
Fairbanksmorse geared mag Question Ray Cardoza Hit & Miss Gas Engine Discussion 5 10-07-2005 01:55:38 AM
Geared vs Servo Shift Glenn Gieszler Machine Shop and Tool Talk 0 08-10-2005 10:33:01 PM
