Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag 72-D in Sacramento!
this thread has 5 replies and has been viewed 1610 times
Old 08-11-2017, 12:21:28 AM
ubernoob51 ubernoob51 is offline
Default Maytag 72-D in Sacramento!
Hi guys! I bought this Maytag 72-D from my local lawn and garden shop, and got it running.
---------- Post added at 09:01:11 PM ---------- Previous post was at 08:58:53 PM ----------
Here's a video of it running.
---------- Post added at 09:21:28 PM ---------- Previous post was at 09:01:11 PM ----------
https://m.youtube.com/watch?v=9g_f4m...ature=youtu.be
The Following User Says Thank You to ubernoob51 For This Post:
Old 08-11-2017, 01:45:01 AM
Ray Cardoza's Avatar
Default Re: Maytag 72-D in Sacramento!
nice runner im almost done with my 72. what fuel ratio did you use the correct is 16:1 with non detergent 30 weight not the modern 2 stroke oils
Old 08-11-2017, 03:33:40 PM
Same oil/gas ratio, but I couldn't find any non-detergent oil for sale here, so I got some Opti-2 2-stroke oil.
If anyone has a source for the correct oil in Sacramento, let me know.
Old 08-11-2017, 04:42:15 PM
im sure napa or walmart would have
Old 08-16-2017, 05:06:04 PM
If you cannot find ND 30 wt oil, a good TCW-3 or marine 2 stroke oil will work fine. NO synthetic or one mix lubricants!. I get my SAE 30 non-detergent from a local NAPA auto parts store.
Old 11-26-2017, 05:49:20 PM
Axenolith Axenolith is offline
I got 30 wt non detergent off Amazon. Just mixed my first batches with it and fired up a 1927 model 92 side exhaust I got for $25 at a swap meet. Runs like a top, smokes like a forest fire LOL.
It wouldn't fire at first but a shot of carb cleaner in the air intake apparently freed the check valve and it took off. I was blown away at how easy those things start, like you rotate it up to near TDC and if your not careful POW, it's going.
New Member From Sacramento ubernoob51 Smokstak Forums Meet and Greet 2 07-21-2017 11:33:46 PM
Greetings from Sacramento hardhatdiver Smokstak Forums Meet and Greet 5 11-30-2014 01:58:54 AM
Whatever Happened to the Collection Along the Sacramento River? bill chasser Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 02-11-2013 12:29:13 AM
Reno, NV or Sacramento CA Magneto repair? dondlhmn Hit & Miss Gas Engine Discussion 4 01-14-2012 09:16:39 PM
Odd barn find Maytag runs again...Maytag prototype or farmer fix? Mac Leod Hit & Miss Gas Engine Discussion 16 11-19-2008 12:45:49 AM
