Electrolysis
this thread has 5 replies and has been viewed 1261 times
Old 08-31-2017, 05:49:08 PM
Dwayne Oxford Dwayne Oxford is offline
Default Electrolysis
If you use a metal can and hang part insulated from can wont it be the same as making a "cage"?
Old 08-31-2017, 07:46:22 PM
Default Re: Electrolysis
Don't do that,it will make a mess.
Cut the bottom out of the can,insert can into plastic bucket,then hang part inside of can. Plastic bucket will hold liquid,metal can will be anode.
The Following User Says Thank You to uglyblue66 For This Post:
Old 08-31-2017, 10:31:50 PM
AngrySailor AngrySailor is online now
Originally Posted by akuna View Post
I do not think so. The anode is sacrificial. In your case the can would be the anode and it will likely get a hole in it and rusty water all over the shop or kitchen.
It is actually the part that is sacrificial as it is negatively charged. I still would use a plastic tub though.
The Following User Says Thank You to AngrySailor For This Post:
Old 09-02-2017, 10:11:18 AM
They don't. If everything is proper they will accumulate the crud the leaves the part. Could be dirty DC, or wrong polarity. Electrolysis cleaning is basically the opposite of electro plating, one removes, the other deposits. Plated parts are "reverse etched" prior to plating to expose new clean metal. I think the definition of "anode" is the confusing issue here, it changes based on weather a device is receiving or delivering current or something like that that I should remember more clearly but the years have fogged
---------- Post added at 10:11:18 AM ---------- Previous post was at 10:07:19 AM ----------
added
ACID rings a bell "Anode Current In Negative" which technically makes the part the anode.
Old 09-02-2017, 12:01:20 PM
DC flows N- to P+. Hmm. Seeing cautions about stainless for P+, http://www.antique-engines.com/stain...electrodes.htm, guess I don't need to use my stainless barrel.
Old 09-02-2017, 08:45:55 PM
Both electrodes will produce gas, mostly hydrogen and oxygen but stainless electrodes off gas some nasty stuff along with.
Electrolysis Using Lye Kid Dynamo Machine Shop and Tool Talk 41 12-13-2018 01:13:48 AM
Electrolysis Massey Guy Hit & Miss Gas Engine Discussion 5 12-10-2014 11:22:18 AM
Electrolysis? jerryreggie Hit & Miss Gas Engine Discussion 1 03-04-2009 09:28:19 PM
Electrolysis Vic Pankoski Antique Engine Archives 15 07-12-2003 11:07:15 PM
electrolysis Fhartman Antique Engine Archives 0 12-14-2002 06:31:52 PM
