Valve grinding pilot question
this thread has 3 replies and has been viewed 1252 times
Old 09-10-2017, 09:14:04 PM
SteveK SteveK is offline
Default Valve grinding pilot question
I have some black and decker valve guide pilots for my seat grinder. What are the 3 fingered ends on the pilot called? They screw on the pilot opposite the stone holder end and expand when you turn the pilot. I have two that are broken. They are 5/16 coarse thread.
On the level
Old 09-11-2017, 06:13:45 PM
Mitch Malcolm Mitch Malcolm is offline
Default Re: Valve grinding pilot question
They are adjustable pilots available after market from Goodson in Redwing MN. last I knew..
The Following User Says Thank You to Mitch Malcolm For This Post:
Old 09-11-2017, 09:33:49 PM
I saw this post last night, I know what you are talking about, but not what they are called, best guess would be expanding collet
Old 09-12-2017, 08:54:05 AM
SparkyMil SparkyMil is offline
They are called a split sleeve and are not sold separately if you are trying to replace them.
The Following User Says Thank You to SparkyMil For This Post:
Makeshift Ford 8N valve seat grinding pilot? Ralph Erb Machine Shop and Tool Talk 6 03-23-2016 01:24:18 AM
Ford 8N Valve grinding pilot stem mounting Ralph Erb Antique Farm Tractors 4 03-17-2016 12:52:38 AM
Help grinding ball valve please. yachtgilana Machine Shop and Tool Talk 12 03-22-2010 02:06:21 PM
valve grinding gene w Machine Shop and Tool Talk 0 04-04-2007 07:01:21 PM
Valve Grinding? DippyNo12 Hit & Miss Gas Engine Discussion 12 11-06-2005 11:11:22 PM
