Early South Bend Question
this thread has 5 replies and has been viewed 927 times
Old 09-23-2017, 12:06:30 PM
wilkesfam wilkesfam is offline
Default Early South Bend Question
I am looking at a South bend with the numbers 20177 stamped between the ways on the bed. The South bend site says that these were the early ways to check the size of the lathe but don't say how. Does anyone have an idea?
Old 09-24-2017, 07:47:45 AM
QuickJ QuickJ is offline
Default Re: Early South Bend Question
I believe the number relates to the build card for the lathe.
It is a serial number, but you would need to contact the factory, who would then pull the build card for that serial number and would be able to tell exactly what size and special features they had put on that particular lathe.
I thought that Southbend (now Clausing) still had access to these cards and would provide you with the information for a fee.
Old 09-24-2017, 07:57:24 AM
Grizzly owns the South Bend assets and you can likely get a build card from them for $25. www.grizzly.com
Old 09-24-2017, 10:55:03 PM
AngrySailor AngrySailor is offline
Do mean how to check the actual size of the lathe? Measue from the spindle centre line to the closes part of the bed or ways for swing, the largest radius that will spin. Then measure max distance between centres. For example 8"x40" would take 16" diameter over the ways (not over the cross slide) by 40" long work piece max
Old 09-25-2017, 08:32:33 PM
dirty tools dirty tools is offline
you can go to http://www.wswells.com/serial_number.html for information on older SB
Old 09-25-2017, 08:59:32 PM
Labradigger1 Labradigger1 is offline
Practical machinist website has the numbers history. Serial no. Should be between the 2 screws of the r/h leadscrew hanger on top of the bed on the front way.
How early? Around 1912 or so iirc they started with the O series model 34's, next series had the double walled ways.
South bend lathe Bryant Machine Shop and Tool Talk 4 01-01-2016 11:39:13 AM
South Bend 10L lathe Pumpkin Machine Shop and Tool Talk 16 03-22-2014 04:47:56 PM
South Bend Threading JoeC6 Machine Shop and Tool Talk 11 02-27-2012 08:11:47 AM
South Bend Lathe?? RIRR Machine Shop and Tool Talk 1 08-01-2007 09:26:13 PM
South Bend Lathe Frank Martin Machine Shop and Tool Talk 5 12-18-2006 11:53:50 PM
