South Bend Lathe Serial #
this thread has 3 replies and has been viewed 1136 times
Old 09-25-2017, 03:30:08 PM
Rod in MN Rod in MN is offline
Default South Bend Lathe Serial #
Hi. Guys. I'm looking at a South Bend Lathe. It is a flat belt drive. Trying to locate the Serial Number on it. I did find the brass plate for the for the speed. It will need the cover that covers all the gears
Thank You
Rod in Mn
Old 09-25-2017, 04:32:09 PM
Default Re: South Bend lathe Serial #
Model code and serial number are stamped into the bed on the left end.
Old 09-25-2017, 08:34:32 PM
dirty tools dirty tools is offline
some information can be found at
http://www.wswells.com/serial_number.html
The Following User Says Thank You to dirty tools For This Post:
Old 09-25-2017, 09:01:19 PM
Labradigger1 Labradigger1 is online now
Top of the bed, r/h side. Between the 2 screws that hold the r/h lead screw hanger to the front way.
South bend lathe Bryant Machine Shop and Tool Talk 4 01-01-2016 11:39:13 AM
South Bend 10L lathe Pumpkin Machine Shop and Tool Talk 16 03-22-2014 04:47:56 PM
South Bend 9" Lathe Marcel P Machine Shop and Tool Talk 4 04-08-2011 06:05:31 AM
South Bend Lathe?? RIRR Machine Shop and Tool Talk 1 08-01-2007 09:26:13 PM
South Bend Lathe Frank Martin Machine Shop and Tool Talk 5 12-18-2006 11:53:50 PM
