Where to find square tool to make a boring bar?
this thread has 8 replies and has been viewed 1408 times
Old 10-03-2017, 08:26:45 PM
Reed Engine's Avatar
Default Where to find square tool to make a boring bar?
I’d like to make a small boring bar to use on the lathe. 1/8” square by 2-3” long. Either high speed steel or better yet carbide. Any suggestions where to find?
Old 10-03-2017, 09:20:54 PM
Ray Cardoza's Avatar
Default Re: Where to find square tool to make a boring bar?
https://www.amazon.com/Speed-Steel-S...are+tool+steel
Old 10-04-2017, 08:27:49 AM
If you're not in a hurry go on ebay and look for metric sizes. 5x5, 6x6, 8x8 etc. They can come in lengths to 8 inches. Cheap and you can cut the length to suit.
*Note that some aren't as hi speed as we'd like to think.
Old 10-04-2017, 11:45:24 AM
I've used a good brand Allen wrench for that with good success.
The Following User Says Thank You to Pat Barrett For This Post:
Old 10-04-2017, 12:12:24 PM
Tanner Remillard's Avatar
I've used these guys when needing small carbide tooling. They make good stuff and I think they make boring bars down to .070 or so http://www.thinbit.com/
Old 10-04-2017, 04:21:08 PM
Nick's Avatar
Nick Nick is offline
Micro 100 and Harvey Tool are a couple more suppliers of small carbide boring bars. I've also made them from old end mills both HSS and carbide.
The Following User Says Thank You to Nick For This Post:
Old 10-04-2017, 04:22:22 PM
Originally Posted by Ray Cardoza View Post
Currently unavailable. But thanks for trying.
Old 10-04-2017, 08:37:15 PM
Mike Hole Mike Hole is online now
Try McMaster Carr
Pt # 3205A59 1/8" x 1/8" x 2 1/2" $8.33 each
Mike
Old 10-04-2017, 09:16:13 PM
Found some on eBay. Thanks for the help.
Cleveland General Motors 16-278A Pneumatic 1” square drive engine turning tool gussuk Machine Shop and Tool Talk 0 08-20-2015 01:29:39 AM
I need a boring tool bit I like oldstuff Machine Shop and Tool Talk 7 04-16-2014 10:32:25 PM
Boring day & Flea Market find turned to IHC Paul Spence Hit & Miss Gas Engine Discussion 6 01-11-2010 10:32:03 PM
Identify fly cutter boring tool ?? VicP Machine Shop and Tool Talk 1 12-02-2007 07:59:00 PM
The Best Find an Engine Man Can Make Lonnie Henry Antique Engine Archives 3 04-05-2003 11:07:38 AM
