Magneto for Mogul 10-20
this thread has 3 replies and has been viewed 711 times
Old 04-10-2018, 03:15:12 PM
colo colo is offline
Default Magneto for Mogul 10-20
Hello,
friend is looking for a KW HT magneto for Mogul 10-20.
Thank you
Davide
Old 04-10-2018, 03:23:32 PM
Exclamation Re: Magneto for mogul 10-20
THIS GOES FOR EVERYBODY! Want ads are not supposed to be in the regular forums. They remain here forever! You could be getting calls 10 years from now! It has happened when old threads are read from the archives! Place a want ad in Enginads section of the Stak. There, they are removed after 30 days. You can renew if nescessary
Old 04-13-2018, 07:56:24 AM
Default Re: Magneto for Mogul 10-20
I have a question:
the magnet KW model T for Mogul 10-20 is a special magnet,
having anti-clockwise rotation?
The impulse starter of a magnet with clockwise rotation can be used for anti-clockwise rotation?
Old 04-13-2018, 03:01:08 PM
Oldtech Oldtech is offline
Mags are often reversible. have to change the impulse dogs and spring around and the rotor will usually be marked for either direction
Mogul 2 1/2 magneto timing pjjms Magnetos, Ignition Coils and Spark Plugs 5 11-03-2011 09:04:49 PM
1 HP Mogul Magneto Roger Eldred Hit & Miss Gas Engine Discussion 3 07-08-2007 09:50:18 PM
1 HP Mogul Magneto TomT Hit & Miss Gas Engine Discussion 3 05-18-2007 09:44:11 PM
Magneto Timing 1 hp Mogul oldironcollector Hit & Miss Gas Engine Discussion 3 11-10-2006 12:03:17 AM
Missing MOGUL Magneto Paul Spence Antique Engine Archives 2 10-13-2000 12:44:41 PM
