Help with American Bosch Mag
this thread has 2 replies and has been viewed 738 times
Old 04-10-2018, 10:33:57 PM
Grape Grape is offline
Default Help with American Bosch Mag
Hello, I've got an old Kohler power and light generator with an American bosch Mag Model MJH 4c B03201.
First question is can someone narrow down the year built? The engine its on is supposed to be 1922 but I think this mag is newer, am I right?
Next. I see a push button kill switch but this rig is supposed to shut down automatically so where would the kill switch wire be located?
I'm not very knowledgeable on these and haven't found much info on the interweb.
Thanks in advance for any help.
Name:	Kohler mag 2.jpg
Phil Grape
Remember, to Belittle others is to Be Little yourself
Old 04-11-2018, 02:49:08 AM
cobbadog cobbadog is offline
Default Re: Help with American Bosch Mag
It is quite possible that over the years the magneto has been swapped over at a reconditioners shop to save on down time. So if it is the original 'style' magneto the auto stop system would have to be connected to the contact for the stop switch.
Hope someone else can really help you out with your question, I'm only offering a suggestion as to your enquiry.
Old 04-15-2018, 09:51:44 AM
edisondiamond edisondiamond is offline
You might want to post this question in the Kohler section. Look at the generator and see if there is an information tag, post the info from it too.
American Bosch, Bosch magneto ZR4 vs DU4 Interchangable? glenshep Magnetos, Ignition Coils and Spark Plugs 4 03-25-2014 02:19:07 AM
American Bosch Mag R Towne Hit & Miss Gas Engine Discussion 5 10-22-2012 03:55:57 PM
American Bosch AT 4 Mag Jerry Magnetos, Ignition Coils and Spark Plugs 1 01-02-2011 08:46:44 PM
American Bosch Mag SethM Hit & Miss Gas Engine Discussion 11 12-31-2008 10:37:20 PM
American Bosch Mag A33 Gus Simms Antique Engine Archives 2 05-31-2001 04:38:03 PM
