Wico EK Magneto
this thread has 3 replies and has been viewed 915 times
Old 04-22-2018, 08:13:34 PM
tristan e tristan e is offline
Default Wico EK Magneto
Hello every one
Recently got a new condenser and points for my wico EK Magneto found on my Massey Harris type 2 stationary engine we got it running and it ran good for about 2 minutes until it died upon further inspection I found that there is no longer any Spark the adjustment that keeps the points set properly became loose and is no longer set right we fought and fought with it trying to tighten up but we have no idea how to keep it tight without messing with adjustment how can I do this with other than using Loctite or something like that
Old 04-22-2018, 08:18:03 PM
Pat Barrett Pat Barrett is online now
Default Re: Wico EK
There should be a small lock washer for the movable contact and the nut locking it to the screw.
Old 04-22-2018, 11:00:14 PM
Default Re: Wico EK
Would you possibly be able to get a picture I was pretty stupid when I took it apart and didn't take a picture of all of what I had or the way it properly went together
Old 04-23-2018, 06:32:05 AM
BV071747 BV071747 is offline
Default Re: Wico EK Magneto
I bet if you get on You Tube and search Wico EK magneto you will find many that explain and show this. I think a guy named Shop Dog has some really good ones
Wico Magneto from a JD LA dadam2308 Magnetos, Ignition Coils and Spark Plugs 3 02-18-2013 08:27:07 PM
Wico ap magneto Help tim w Magnetos, Ignition Coils and Spark Plugs 1 01-10-2013 05:21:37 PM
Wico EK Magneto JohnCCarlson Magnetos, Ignition Coils and Spark Plugs 2 06-18-2009 09:46:03 PM
IHC LA Wico Magneto Dennis Buswell Antique Engine Archives 0 03-02-2004 12:09:54 PM
Wico EJ magneto Jerry Larner Antique Engine Archives 2 01-04-2004 04:34:38 PM
