Webster Query
this thread has 4 replies and has been viewed 830 times
Old 04-25-2018, 09:17:28 AM
pulsechoes pulsechoes is offline
Default Webster Query
Still relatively new to the US-built engine scene, I need an answer to this question. Can someone tell me the difference between an "M" and an "MM" Webster magneto. I'm looking for a mag/bracket/ignitor/striker for a little Turner Simplicity 1.5hp, I need an MM mag and my buddy has an M spare. Are they interchangeable??
Old 04-25-2018, 11:06:36 AM
Default Re: Webster Query
The M uses a single heavy magnet; the MM uses a double heavy magnet. The mounting should be the same making the two mags interchangeable.
Hopefully someone else will chime in and confirm that.
Old 04-25-2018, 12:20:46 PM
Renny Renny is offline
Is there anything out there that shows the different types of Webster magnetos?
Old 04-25-2018, 02:55:15 PM
Doug Wilson Doug Wilson is offline
Their used to be a reprint of all Webster mags , showing the different sizes, as well as different trip styles. I don't know if they are still available or not.
Old 04-25-2018, 08:56:59 PM
Les Layton Les Layton is offline
I have several copies of the Webster magneto book By Doc Schuster Send me a private message with your address & I can send you one Very nice book. Les
Lister CE 11.5HP Query KrisDouglas Vintage Diesel and Oil Stationary Engines 0 01-21-2014 07:59:19 PM
blackstone query john gilbert Smokstak Down Under 1 04-07-2013 11:16:30 PM
5LB thread query junction 28 Hit & Miss Gas Engine Discussion 6 08-23-2011 04:26:21 PM
Coolant Query Major Tom Onan Generators 8 01-14-2011 10:19:33 AM
engine query David Zimmerman Antique Engine Archives 0 06-02-2002 02:28:21 AM
