Continental AU85 no Spark...
this thread has 5 replies and has been viewed 830 times
Old 05-04-2018, 01:45:59 PM
oldmotorette oldmotorette is offline
Default Continental AU85 no Spark...
I have new condenser. New points. New spark plug.
The engine started and ran yesterday. Idled well and revved just fine.
Ran it for 10 minutes or so, then shut it down.
A few hours later, it wouldn't start. Not a pop.
Checked for spark. Zero.
Pulled the flywheel, checked for continuity in spark plug wire. It's fine.
Where would I look next?
Coil?
Any way a low-skills guy could test it?
If needed - any idea where to get a replacement?
Thanks!
Old 05-04-2018, 10:14:12 PM
s100 s100 is offline
Default Re: Continental AU85 no spark...
Does this one have the points/governor under a little cover on the crankcase of the engine? I would start with things that are most likely to cause problems. With ignition systems the first stop is the points, condenser and related stuff. Yes, they are new. but maybe you got distracted and left a screw loose, maybe a wire is shorting against some metal, maybe some dirt got in the contacts, or maybe the condenser is plain old bad. Try the old one to see if that helps. If you have a new plug handy try that. Also check the plug wire CAREFULLY. I have had several engines over the years that would run or not run with nothing seeming to change, completely at random. Every such instance was caused by a spark plug wire with cracked insulation that, when pressed together or at some distance from metal would work fine but as soon as the crack opened and/or the wire moved closer to metal, out went the lights. Next check the magnets. They should pull strongly at a screwdriver or hacksaw blade. If all of that stuff is good then you can try checking the coil. Can't say for sure but if you put an ohmmeter on the primary side (between the wire going from the coil to the points and ground) I would expect to see something less than 10 ohms. The secondary side (plug wire to ground should be several thousand ohms.
Old 05-04-2018, 10:23:32 PM
Butch Yowell's Avatar
Butch Yowell Butch Yowell is offline
Check the point setting.
Butch Yowell
Old 05-04-2018, 10:28:27 PM
Thanks! I'll try it all - and report back.
Old 05-09-2018, 03:09:22 AM
cobbadog cobbadog is offline
Default Re: Continental AU85 no Spark...
I always start with a new spark plug and a testing of that. Always run a wire HT lead from magnetos as carbon ones break down all too quickly. A possible problem was that the coil failed once it got hot. A multimeter that can read both ohms and capacitance is best to get answers on condition of coils and condensors. I have been using film capacitors instead of condensors and find them more reliable. Always as suggested clean and adjust your points. It is important they are spotlessly clean and adjusted correctly. Good luck with your trouble shooting and let us know how you get on.
Old 06-22-2018, 02:08:39 PM
An old trick at a shop I used to work for was this: Remove the spark plug and ground the base. Put it where you can see if spark occurs. Remove the flywheel and or magnet assembly. Open the points. Take a 9 volt radio battery and ground one side. Take a wire and quickly touch and then remove from the coil wiring, where it meets the points. You should see virtually no spark when you touch the wire to the coil wiring, and when you break the battery connection, a spark at the plug.
If you get a flash at the wire connection, you either have a grounded wire, a bad coil, or bad condenser Check your connections for a grounding fault first. A stray wire that causes a short, misplaced isolation washers, etc. make sure your points gap is right and that the points are opening and closing. Sometimes the points pushrod (plunger) can stick, especially if the engine was sitting a while. If your engine has the points under the flywheel, again check connections and that the points are opening and closing. try running a white business card thru the points. If it comes out grey or oily, they are dirty.
No spark-Continental AU85 3HP cheeshead Magnetos, Ignition Coils and Spark Plugs 4 02-13-2013 07:24:44 PM
Can this Continental AU85 be saved? dw1973 Small Air Cooled Gasoline Engines 9 05-20-2012 10:54:07 AM
Continental AU85 Military j ridings Small Air Cooled Gasoline Engines 1 04-11-2011 09:14:00 PM
Continental AU85 aircoolengine Small Air Cooled Gasoline Engines 7 03-19-2011 06:42:06 PM
No Spark Continental AU85 Jim Cobb Small Air Cooled Gasoline Engines 9 04-21-2009 12:45:53 AM
