Maytag model 72 D-A
this thread has 2 replies and has been viewed 750 times
Old 05-09-2018, 04:49:53 PM
Big Boose Big Boose is offline
Default Maytag model 72 D-A
I have a model 72 D-A that is missing the coil, condensor, and armature. The serial # on the Eisemann flywheel is 111571 X. Since this engine was partly torn down when I got it, I'm not sure this is the correct flywheel. Would anyone know if it is correct and where I may find the missing parts? This engine is on a Zip push mower manufactured in Baxter Springs, KS. Thanks
Old 05-10-2018, 04:58:01 PM
Kevin Weis Kevin Weis is offline
Default Re: Maytag model 72 D-A
Take it the armature back plate is there? Just as well, the coils are typically bad in these and you would need to secure a new coil which is about $150. The condenser another $15.00 or so, and an armature another $15 maybe. Unless its something special otherwise in my opinion not worth the restoration. Put the money into a running one. Hard to tell if it was originally an Eisemann or a Wico. Serial number on Flywheel will just be able to determine the year only. My two cents. Kevin
Old 06-22-2018, 01:54:54 PM
Without knowing if the flywheel or mag is original, you probably would need to replace both the backing plate assembly and flywheel as a matched set. You cannot mix the 72 D and DA mags and flywheels, they have a different ID and magnet. The basic engine is the same for all 3 mag types, you just need to use the flywheel and backing plate for the same model. You might be better off finding a blown motor and try getting the magneto assembly. To buy new is not worth it if you do not know the type. Cost wise, you probably could get a running engine for the cost of a new mag coil, plus you have to figure in the cost of the armature core and condenser as well. Not worth it in my book, unless the engine has a sentimental value.
Maytag model E2L mrbb Antique Washing Machines 2 03-08-2016 05:20:51 PM
New Hit and Miss Owner JD Model E Maytag Model 92 Heelerman Smokstak Forums Meet and Greet 2 10-08-2014 02:24:28 PM
Maytag model 30 RJ59 Antique Washing Machines 1 01-02-2014 08:02:50 PM
Maytag Model 92 Oiler Ball Oil/Etc. (New Model 92 Owner Questions) KubotaDiesel Maytag Engines and Collectibles 7 11-17-2013 04:35:25 PM
Maytag Model 19 Turbo Maytag Engines and Collectibles 3 05-26-2011 01:47:28 AM
