FM J Mag Help
this thread has 5 replies and has been viewed 930 times
Old 05-16-2018, 03:29:07 PM
bill chasser bill chasser is offline
Photo FM J Mag Help
I’m having an issue with the pulse coupler operation on an FM-J. The lever on the snap coupling had a tiny spring to push the lever outward to hit a stop on the outer case. The problem is it is not consistent in its operation when preparing to start the engine I took the coupler off and found that there is some magnetism to the snap coupler body causing the flyweight portion of the arm to be stuck to the body which overrides the strength of the wire spring. Am I correct that this should not be magnetized so as to allow the lever to operate freely and that it is the centrifugal force once the engine is running that prevents constant snapping of the coupler.
Should I degouze the coupler?
Old 05-16-2018, 03:58:00 PM
mmcdonald mmcdonald is offline
Default Re: FM J mag help
It should not be magnetic. A growler will fix that quickly if you have access to one. Put the part in the "V" of the growler. Turn it on and then remove part, then turn growler off. Do not leave growler on more than a second or two without something in the "V", can cause damage. This has always worked for me.
info@mcdonaldcarb.com
The Following User Says Thank You to mmcdonald For This Post:
Old 05-16-2018, 06:36:57 PM
Photo Re: FM J mag help
Thanks. Yes I have taken care of it and it now works correctly. I think the mag shop recharged the magnets and didn’t protect the coupler.
Next question. Working on another FM-J mag with a similar symptom in that the snap coupler isn’t working. Upon removing the mag it is missing the pin in the housing that the mag coupler lever is suppose to but up against. I need the slot head pin that screws into the case. Is there a parts source for these? I don’t have any spares
Bill
Old 05-16-2018, 06:41:25 PM
stufforbud stufforbud is offline
I've got lots of those. Send me an email with your address and I'll send you one. Are the threads in the housing good?
Bud
Old 05-20-2018, 01:37:59 PM
Bud thank you for your offer. I can’t tell if the threads are good at this point. I disassembled the engine this mag was on and it wasn’t inside. I’m assuming the mag had been removed for a repair in its history and someone failed to put the pin back in place. I’ll try to look at the housing closer today.
Bill
Old 06-05-2018, 04:30:20 AM
Default Re: FM J Mag Help
Bud you have new Email
Bill Chasser
