Webster Type 1 & 2?
this thread has 4 replies and has been viewed 747 times
Old 05-29-2018, 11:49:15 AM
Weezer Weezer is offline
Default Webster Type 1 & 2?
Greetings,
Can anyone tell me the difference between a Webster type 1 and "new style type 2" magneto? I have a tri-polar 2 magnet AK, sn 658224. I want to put new coils in it, but want to be sure of what I have.
Thanks!
Jim
Old 05-29-2018, 02:25:20 PM
Mitch Malcolm Mitch Malcolm is offline
Default Re: Webster Type 1 & 2?
That would be a first model K coil set
The Following User Says Thank You to Mitch Malcolm For This Post:
Old 05-29-2018, 02:54:50 PM
The mag internals were different, as well as the trip mechanism. Personally, I feel the type 1 was the best. Check the sponsor pages for mag venders - they should be able to hook you up with new coils easily. Lee Pederson may have then, I know H&M Enterprises does but the wait on H&M???
Old 05-29-2018, 05:51:36 PM
Thanks Mitch and Andrew. I was set to pull the trigger, then saw mention of "new style Type 2" and thought I'd better be sure. I was installing new end plates and springs I bought from Lee and found the cross over wire bare. I'm going to try wrapping it first, It's too tiny for me to attempt to solder. If it works, I'll let it ride, if not, new coils it is. Thanks!
Old 05-30-2018, 06:41:32 AM
BV071747 BV071747 is offline
I bought my last set of coils from Mitch Malcolm, ligthning Magneto.
The Following 2 Users Say Thank You to BV071747 For This Post:
Webster Type JY 1 Stephen Porter Magnetos, Ignition Coils and Spark Plugs 6 07-11-2017 05:56:42 PM
Webster Type F Greg Shipley Magnetos, Ignition Coils and Spark Plugs 3 06-23-2012 11:23:31 AM
Webster Type K Elwood Magnetos, Ignition Coils and Spark Plugs 0 02-12-2011 11:53:14 PM
Webster Type 1 Mag Mark Booth Magnetos, Ignition Coils and Spark Plugs 0 10-03-2006 09:10:11 PM
What type Webster Mag Ralph Leonard Antique Engine Archives 3 11-13-2002 07:09:39 PM
