Oil Burner Ignition Coils
this thread has 5 replies and has been viewed 789 times
Old 06-01-2018, 04:17:49 PM
opus opus is offline
Default Oil Burner Ignition Coils
Long story short; I have a Webasto 12v fuel oil burner. It has a 12v coil that goes to 2 electrodes. Mine died, a new one is $500...yes, $500 for a coil.
Question is, how can I improvise? After all, a coil is a coil....yea?
Old 06-01-2018, 05:04:57 PM
Default Re: Coils....
You might get away with a K&W model T coil. They put out about 40,000 volts compared to the 15 to 20000 a ford coil puts out. The spark has to be really hot to light fuel oil. You don't want to get bit by a K&W coil either! It all depends on what the controls put out to the coil, and if the resistance and power demand meet the burner's needs. Have you tried an on-line source for parts?
Old 06-01-2018, 06:24:03 PM
Elden DuRand's Avatar
Once, when the ignitor transformer in our oil furnace went belly-up (on the coldest Saturday of the winter, (natch); I rigged an old neon sign transformer to do the job. It worked like a champ.
That was good because it took a couple of weeks to get a replacement.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 06-01-2018, 07:33:37 PM
Oh yeah, I can find the coil, but I'm not paying $500 give or take.
Old 06-01-2018, 09:24:11 PM
debe debe is offline
This s what I came up with to replace a very expensive igniter for a Karcher diesel powered pressure cleaner. Using a car ignition coil. The Karcher & the ign coil & switching transistor all came free from local Scrap yard, is a great machine now.
Name:	KARCHER IGNITER.1.jpg
ID:	311603   Click image for larger version
Name:	KARCHER IGNITER.2.jpg
ID:	311604   Click image for larger version
Name:	KARCHER Steam cleaner.1.jpg
ID:	311605   Click image for larger version
Name:	KARCHER IGNITER Circ.jpg
Old 06-01-2018, 09:34:21 PM
I'm not THAT smart!
Ignition testing,coils and such uglyblue66 Small Air Cooled Gasoline Engines 2 10-06-2013 09:28:51 PM
Unknown Ignition Coils Jason Dahm Hit & Miss Gas Engine Discussion 5 01-22-2013 09:05:33 PM
Ford Ignition Coils Tom Wahl Antique Autos and Trucks 1 12-04-2010 11:45:57 AM
Small ignition coils chrsbrbnk Scale Model Engineering 2 03-01-2010 11:04:45 AM
Ignition coils Christian Berlin Magnetos, Ignition Coils and Spark Plugs 8 12-08-2008 09:45:47 PM
