Antique Spark Plug
this thread has 7 replies and has been viewed 1197 times
Old 06-08-2018, 06:30:26 PM
Rick P Rick P is offline
Default Antique Spark Plug
I found these spark plugs in a machinist tool box bought at auction ! Black porcelene with no mfg name or # . Anyone know there applications ?
Old 06-08-2018, 08:07:56 PM
KeithW's Avatar
KeithW KeithW is offline
Default Re: Antique Spark Plug
They look a lot like aircraft plugs.
The Following User Says Thank You to KeithW For This Post:
Old 06-08-2018, 09:06:52 PM
K-Tron K-Tron is online now
Auburn made a lot of three prong sparkplugs, perhaps an old catalog might turn something up. I doubt it is aircraft, as it is not a radio shielded plug.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 06-09-2018, 08:12:14 AM
ChipTosser ChipTosser is offline
Not all aircraft plugs are shielded.
Not until they started to have radios. For example,My 42 cub uses standard 14mm plugs.
What is the thread size? They could be marine, outboard.
---------- Post added at 08:12:14 AM ---------- Previous post was at 08:10:56 AM ----------
They are not that old, they are taper seat.
The Following User Says Thank You to ChipTosser For This Post:
Old 06-09-2018, 09:28:20 AM
John Newman, Jr.'s Avatar
J.C.Whitney "Fire Injectors"?
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 06-09-2018, 03:08:48 PM
Oldtech Oldtech is offline
Look similar to aircraft to me. Should be a number stamped on them though. Air parts are never unidentified.
The Following User Says Thank You to Oldtech For This Post:
Old 06-09-2018, 03:35:43 PM
DustyBar DustyBar is offline
There were several auto plug manufactures that had multiple electrodes arranged just like that. That arrangement was not unique to aircraft only.
The Following 2 Users Say Thank You to DustyBar For This Post:
Old 06-22-2018, 01:42:49 PM
They look like 18mm tapered seat. You might try to contact the park Plug collectors Club of America (SPCOA). They might have some idea for you.
splitdorf spark plug anyone know what it would have been in very unusual plug Britstand Smokstak Down Under 6 09-04-2016 08:00:28 PM
AC Spark Plug Div 4 Break Metal/Ceramic Plug? Bud Tierney Magnetos, Ignition Coils and Spark Plugs 3 01-08-2013 08:08:52 PM
Replacement Spark Plug for Maytag Uprights?? Modern Plug? enginesilo Maytag Engines and Collectibles 3 08-31-2008 01:21:57 AM
Antique spark plug threads gafisk Hit & Miss Gas Engine Discussion 4 02-28-2008 10:27:51 PM
Antique Brass and porcelain spark plug M. Smith Antique Engine Archives 4 09-19-2003 06:52:34 PM
