Kohler K91T Ignition Upgrade
this thread has 4 replies and has been viewed 563 times
Old 06-22-2018, 01:22:11 PM
AndrewJ AndrewJ is offline
Default Kohler K91T Ignition Upgrade
Can the K91's points and condensor ignition system be converted to an electronic ignition system?
Old 06-22-2018, 08:29:32 PM
debe debe is offline
Default Re: Kohler K91T Ignition Upgrade
You should be able to replace the points & condencer with an Atom Ign module.
The Following User Says Thank You to debe For This Post:
Old 06-22-2018, 10:56:46 PM
K-Tron K-Tron is offline
Why would you want to replace the tried and true points setup on your Kohler? With a little searching you can find NOS points and condenser without trouble. In my opinion, battery ignition and or electronic ignition (Atom/Pertronix) is not an upgrade, its a downgrade.
Chris
The Following 3 Users Say Thank You to K-Tron For This Post:
Old 06-22-2018, 11:03:53 PM
s100 s100 is offline
What Ktron said.
Why would you want to replace something dead simple and reliable, that can be fixed in a jiffy if something goes wrong, with a little mystery cube that either works or it does not? It's true, all cars have had electronic ignitions for years but it's not a good comparison to try to equate those sophisticated and highly engineered systems with some gadget that was cooked up by some small time entrepreneur. Do ourself a favor and stick with the tried and true.
The Following 3 Users Say Thank You to s100 For This Post:
Old 06-22-2018, 11:58:56 PM
Thanks for the response guys.
The topic came up and I thought I would ask here to see what you folks had to say. I've already found replacement parts for the points and condensor.
Kohler K91T AndrewJ Small Air Cooled Gasoline Engines 23 07-06-2018 10:28:27 PM
Onan 6.5 NHE Electronic Ignition upgrade JnyQst Onan Generators 18 09-06-2016 10:52:45 PM
kohler K91t ignition problems James Wallace Garden Tractors and Mowers 1 06-20-2015 02:48:15 PM
Cheap ignition upgrade? bobbyz72 Onan Generators 2 02-16-2010 11:08:02 PM
Kohler K91T carb settings fastball68 Small Air Cooled Gasoline Engines 7 03-13-2006 02:18:13 PM
