FM type R Magneto Application
this thread has 2 replies and has been viewed 627 times
Old 07-11-2018, 09:06:24 AM
Firewoodguy's Avatar
Firewoodguy Firewoodguy is offline
Default FM type R Magneto Application
had this mag in storage and it shows several numbers at the base. im curious to what these numbers are for? serial number? possibly these numbers are for dating the mag? can someone tell me if all of the FM type R have this number pattern at the base? also had a friend tell me this mag was used on early motorcycle engines? thank you for your input.
ID:	313986   Click image for larger version
ID:	313987   Click image for larger version
ID:	313988   Click image for larger version
Old 07-11-2018, 09:08:41 AM
Default Re: FM type R magneto APPLICATION
25 tooth gear
Old 07-11-2018, 11:26:35 AM
Mitch Malcolm Mitch Malcolm is offline
Default Re: FM type R Magneto Application
Your R was used on a couple different models of FM Z engines with that gear it was mainly used on the dishpan flywheel engines 1 1/2 -2 hp depending on the rating... Not used on anything but FM engines but adapted to different ones
The Following User Says Thank You to Mitch Malcolm For This Post:
Edison AJ-1 magneto, what application would have used this ? markH Magnetos, Ignition Coils and Spark Plugs 2 11-09-2015 09:52:37 PM
what is the application of this magneto? Charlie Mc Magnetos, Ignition Coils and Spark Plugs 1 11-08-2012 07:32:22 PM
Magneto Application Question J Kocak Magnetos, Ignition Coils and Spark Plugs 1 01-14-2009 08:42:31 PM
Bosch magneto application KidDynamo Hit & Miss Gas Engine Discussion 1 07-21-2006 04:36:23 PM
Magneto Application jerry larner Antique Engine Archives 0 11-12-2003 09:16:10 AM
