Fairbanks Morse 6 Hp Z Motor Governor?
this thread has 2 replies and has been viewed 521 times
Old 07-12-2018, 07:16:23 AM
pdisciglio pdisciglio is offline
Default Fairbanks Morse 6 Hp Z Motor Governor?
Hello All,
Helping a neighbor with his Fairbanks Morse 6 hp Z hit & miss.
We got it running yesterday, but need to adjust the speed of the motor.
I need to slow it down a bit.
To slow down the motor am I correct to loosen the springs on the governor?
The motor is running so fast I am afraid to start it again without making some type of adjustment to slow it down a bit.
Thank you in advance for your help.
Pat D
Old 07-12-2018, 07:30:46 AM
willisd1 willisd1 is offline
Default Re: Fairbanks Morse 6 Hp Z Motor Governor ?
Weaker springs will slow the engine down
Old 07-12-2018, 09:51:01 AM
David M. Lyon's Avatar
Default Re: Fairbanks Morse 6 Hp Z Motor Governor?
What model 6 horse do you have? there should be an adjustment thumb screw beside the governor, but the linkage to the throttle plate good also be out of adjustment. and have the throttle open. Shorten the rod and see what it does. You can manually hold the throttle rod closed to stop it running away.
Fairbanks Morse Governor Chrisfairchok Hit & Miss Gas Engine Discussion 7 12-29-2017 10:33:09 AM
Fairbanks Morse Z governor question AKMark Hit & Miss Gas Engine Discussion 2 07-04-2017 01:54:54 PM
Fairbanks Morse ZC 208 governor otto Vintage Diesel and Oil Stationary Engines 6 08-21-2012 11:37:41 AM
Fairbanks-Morse ZC Governor petrol smoker Hit & Miss Gas Engine Discussion 0 06-22-2008 01:17:27 PM
Fairbanks Morse governor jd_mike Antique Engine Archives 1 08-30-2002 08:14:56 PM
