Wico Model C on John Deere B
this thread has 2 replies and has been viewed 552 times
Old 07-16-2018, 09:14:32 PM
Sawmill7 Sawmill7 is offline
Default Wico Model C on John Deere B
Impulse on catches once in a while when out and on the bench. The levers look ok but the catch for them looks very worn. Can this be repaired or replaced? Thanks for any help. Bill
Old 07-17-2018, 07:32:36 AM
Kelly Barnett's Avatar
Kelly Barnett Kelly Barnett is offline
Default Re: Wico Model C on John Deere B
The "catch" you mention is on that adjustable plate in the back of the mag. Yes it can be changed with a good one. You will need to take the impulse / drive out and then the 4 screws that hold the plate in place. Make sure you make note of where the plate is rotated to so you make sure the impulse timing doesn't change from where you have it currently.
Old 07-17-2018, 10:45:47 PM
Thanks Kelly, do most mag repair guys carry the plate or need to go to a large repair shop? Thanks again for your help. Bill
WICO series C magneto end play John Deere short lug edisondiamond Magnetos, Ignition Coils and Spark Plugs 4 04-28-2016 04:36:34 PM
Just Completed a Scale Model John Deere Model E Roger U Scale Model Engineering 9 12-22-2012 04:29:21 PM
John Deere WICO H magneto question edisondiamond Magnetos, Ignition Coils and Spark Plugs 6 11-09-2012 01:29:15 AM
John Deere model E Engine, Little John niceonetidy Scale Model Engineering 5 11-01-2012 07:36:24 AM
john deere d wico magneto Mike Privett Magnetos, Ignition Coils and Spark Plugs 1 10-26-2009 01:23:21 PM
